And my V5 @ 3500kg? Down plated do you think?I have a Carthago and the left plate is the Fiat plate and the right one is the Alko plate. In my case the Alko plate is the correct one.
Revenue weight is 3500kgsI always thought that the converters plate over rides the Fiat plate!!!
either way
it looks as if the official weight is over 3500kgs, unless there is another Cathago plate somewhere, what does the V5 say the Revenue weight is.
as far as i am aware the V5 only shows the revenue weight that is what your road tax costs. it is the last plate fitted that i believe to be the legal loadings of the chassis.And my V5 @ 3500kg? Down plated do you think?
either way
Yes it does - one exclamation mark would suffice if any at all.I always thought that the converters plate over rides the Fiat plate!!!
either way
Yes I realise that but there is no allowance for loading, usually the axle weights add up to more than the gross weight.1850 plus 2000 is 3850, so the max load on the rear is 2000 and the front is 3850
No I think it's been uprated to 3850kg according to the left plate!Hi
Recently bought our Carthago A class and the V5 says 3500kg.
Just inside the cab door are two plates.
Has it been down plated to 3500kgs do you think or am I reading this entirely wrong?
What are your thoughts?
So, do we think it was built as a 3850 and then down plated to 3500
It's not been uprated, well sort of, that's the new weight plate from the converter when converting from Fiat chassis cab to motorhome.No I think it's been uprated to 3850kg according to the left plate!
Not that I know anything about A classes I lurk in the self build bilge.
Cheers James
If 3500kg there will be a plate elsewhere.
Cheers James
A class, therefore no slam panel.it could be on the slam panel under the bonnet.
Capital I please !!!it could be on the slam panel under the bonnet.
do you really think 3 exclamation marks are necessary? and, as for 3 imoji's you are really letting standards slip!!!Capital I please !!!
Yes Lenny, it’s a C Tourer.There should be a 3rd converters plate from Carthago and that is the only one that counts.
As its on the light AMC chassis I assume it is either a Compact Line or a C Tourer they are often sold at 3500 kg most are tight to run at that so worth uprating to 3850.
I expect is was built as a 3500, I don't think they offer a 3850 option just 4250 on the maxi chassis.Yes Lenny, it’s a C Tourer.
I can’t find the third plate though.
I don’t have a problem going up in weight. I just wondered if it was built to 3850 and then down plated to suit the customer who bought it new. Therefore, it should be a simple exercise to get it back up.
So what is your thoughts 3850 on the plate Lenny? Does that just mean the AL-KO chassis would normally be a 3850?I expect is was built as a 3500, I don't think they offer a 3850 option just 4250 on the maxi chassis.
Unless it's one of the shorter ones it will be very tight to run at 3500.
