Weighed the Alpa I 7820 today. (1 Viewer)
Bustup15
1,486
3,731
Durham
Dethleffs I 7820-2
New to motorhomes 2019
Just back from Germany and thought I would get a marker for payload.
Virtually emptied the contents/consumables
Full diesel 120 litres
Full water 166 litres
32 inch TV, smaller TV to front cab, speaker system, satellite
Twin solar, 1 gas bottle, twin leisure batteries, inverter and a 6 metre electric awning.
180 hp engine and auto box
Plate below to max 5400kg
Weighbridge at 4680
Front 1980
Rear 2700
720kg to play with and flexibility to dump some fresh if required and or not run with full diesel
Weighed at local authority site and when I requested front rear and total they wanted to charge me for 3 tickets - that can't be normal or is it!? They agreed to do tot weight on ticket and then noted down separately the split weights though.
funflair
19,341
30,213
Guisborough
MORELO palace
since 2012
I don't know if that was with two people in as well but you might need some weight in the garage to balance it out a bit.
But you have a few 100kg to play with looking good.
Martin
Sep 1, 2018
1,985
6,650
Strathaven
Pilote G741
Since 2018
Web site quotes 4260?
I think that’s for the 5000kg , as it’s been updated to 5400kg
The mro will be higher
I am keen to try and work out how accurate the mro is ( bearing in mind the mro is subject to +/- 5% ) , I have a brand new Dethleffs coming in 2 months , if mine was 5% over it will add on 188kg
Oct 29, 2016
4,504
52,714
Surrey
Carthago C Tourer
Council Weigh Bridge in Wellington Somerset, wanted £10 per axle, plus £10 Overall.
So £30 Robbing B's:(:mad:
Les
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
@Bustup15 I’ve just noticed your location.
Do you know there’s a free self weigh facility just outside of Wingate on the A181, just before the A19 sliproad ?
I have used it a few times over the years and it was great for my tag axle as it provided individual rear axle weights, rather than risking being ok on the combined figure, but the rearmost on mine was always higher than the other and close to its maximum when loaded with bikes etc.
You don’t get a printed ticket, nor do you need one. You press the button and drive forward slowly, as each axle passes over the plate, you have to note the weight on the display ahead of you.
Bustup15
Bustup15
1,486
3,731
Durham
Dethleffs I 7820-2
Cheers, will give that a go
funflair
19,341
30,213
Guisborough
MORELO palace
since 2012
@funflair How do you calculate ' balanced'?
Hi Bustup
What I am saying is that your available payload of 720kg is balanced between 320kg spare on the front axle 500kg on the rear axles, if the vehicle was weighed with just one person up front you need to take the passenger weight predominantly off the front axle figure as the weight is loaded so far forward. So lets say that you now have 650kg left to use, if this is loaded on or behind the rear axle that would be overloaded and likewise if it is too far forward it will overload the front axle so it needs to be balanced around the van which it naturally will be, the easiest thing to do is visit the weigh bridge again in full touring trim and try to weigh all three axles as Ken says.
Martin
Apr 13, 2012
5,543
18,773
Mobilvetta Euroyacht
1996, then break 'til 2011
Never having weighed a MH can I ask how uprating a vehicle actually makes it safer to drive?
Just asking
funflair
19,341
30,213
Guisborough
MORELO palace
since 2012
Just asking
Uprating the suspension might take it off the bump stops and give it some compliance which I would have thought would be safer, uprating the tyres means that they will run within their maximum allowed figure.
Martin
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
Just asking
I don’t consider mine to be any safer since uprating it. It does keep me legal if I take the weight over the pre-uprating maximum.
Edit - Mine was only a paper exercise without any physical changes.
Apr 13, 2012
5,543
18,773
Martin
But I have read on here that sometimes it's just a 'paper exercise'
@Kingham beat me to it:)
funflair
19,341
30,213
Guisborough
MORELO palace
since 2012
In that case refer to Ken's answer above but that should only be an available option if the running gear is deemed to be safe at that weight.
Martin
Bustup15
Bustup15
1,486
3,731
Durham
Dethleffs I 7820-2
Hi Bustup
Martin
Bustup15
Bustup15
1,486
3,731
Durham
Dethleffs I 7820-2
@Scotch mist
From coc 4575 but mine was weighed with full water and fuel and driver only (and fuel tank is upgraded so not sure if the % of fuel included is updated in the miro?
May 23, 2008
2,481
3,483
Near Durham City
Carthago
Since 1984
I'm fortunate to have a few customers (Durham) with weigbridges so lucky.
Apr 13, 2012
5,543
18,773
I bought my 2001 Moby 190 knowing it was 3850kg and that I would have to get my C1 back. The seller hadn't realised it was over 3.5t. and he didn't have a C1
Obviously he had been (unwitingly) breaking the law with possibly no ins cover
Has anyone actually been stopped and weighed?
Jan 16, 2014
1,340
2,459
Surrey
Rapido 854f
Since 2012
Never been stopped and weighed but other than main holidays, generally travelling at weekends and not noticed any weigh bridges open to be honest.
Jul 29, 2013
9,071
18,510
Salisbury
Hymer B678DL A class
since 2011
Just asking
If you have never weighed a Motorhome how do you know you are not over weight?
Just a thought as I always weigh the van before most trips if they are long ones with extra kit on board just to ensure we are ok, I know most times what the vans approx weight would be as I weighed it empty and everything we put in was weighed and listed.
I know we don’t hear of many vans being stopped and weighed but you never know who’s waiting around the corner. Better safe than sorry.(y)(y)(y)
Jul 29, 2013
9,071
18,510
Salisbury
since 2011
Why not just take your fully loaded van to the weighbridge once. Then you know what it weighs. You don’t need to do it every trip.
Yes that’s ok for the shorter trips it’s when we get of to Spain for three or for months as I say I know roughly what it’s going to be but for the sake of a trip to the free weighbridge it’s worth it for piece of mind.(y)(y)(y)
Sep 1, 2018
1,985
6,650
Strathaven
Pilote G741
Since 2018
No towing capacity if you wanted it though?:(
I’m not going to tow , will have a scooter in my garage , I was just trying to work out how accurate the stated brochure MRO is , bearing in mind the MRO is subject to +/- 5% , a quick look is very encouraging, a rough guestimate shows it could even be in the - rather than the usual +
If my MRO was +5% that would loose me 188kg in payload
Dec 24, 2014
9,212
47,552
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Blimey! I couldn't be bothered with all that malarkey. :rolleyes: You must be near the limit.
I weighed mine just the once when fully loaded (fuel, water, clothes, food, gas, Boys' toys etc) for a month's trip and had 450kg to spare. I don't buy extra stuff when away and never bring that much wine back.
Kingham
2,683
6,742
Kirkcudbright, D&G
AS Kingham 2017
Since 2009
That’s the way I did mine, fully loaded for worst case scenario and gave me plenty of spare capacity left over. Full tanks, Labrador, kayaks and paddle kit, clothing & food for holiday, awning, windbreak etc
It will take a big change before I would feel the need to revisit the weigh bridge, something like adding a tow bar, towball mounted bike rack and a couple of bikes, along with everything else I carry, just to check the rear axle is still legal.
Jul 29, 2013
9,071
18,510
Salisbury
since 2011
Well we tow a car trailer which I have to ensure we don’t go over GVTW when we are loaded and off to Continent we are around. 5750 kg gvtw and the van alone is
4300 kg so a little to spare(y)(y)
We do travel with full fresh water for the trip so have quite a lot of spare capacity if we dump some.
