Webasco heating (1 Viewer)
eddie
8,144
41,181
Taunton Somerset
RV
since 1989
LOL This is getting out of hand. John has said that they have experience of the problem in their van.
It is nothing to do with the Webasto, but, it would seem the incorrect gauge of wire used originally.
It doesn't need to carry 170 amps nor 100amps from memory when we install them the main fuse is rated at 15 amps
So if a replacement cable is to be used, wired direct from the battery any sized cable that would deliver say 25 amps at the Webasto fuse holder, when distance etc is taken into account.
Eddie
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
I chucked in some 6mm I had laying about for the 3m run required.
No faults since!:thumb:
May 29, 2013
2,589
19,167
Tyneside
Chausson best of Flash 10
Several years now
If it's off a 15A fuse then 2.5mmsq or 32/0.2mm stranded would do the job fine, if you still think it's too low an ampage double the cables. You've only got a few metres run so the voltsdrop is miniscule.
kelpbeds
100
12
shrewsbury
c class
since 2006
Tim, a cable as thick as someones little finger would be about 25mmsq, which could easily carry the power to your house !! It's also pretty expensive and impossible to crimp without special tools.
Sure you are right, it was just I spoke to Mr Sterling from Sterling power supplies and that is what he quoted to me, so connected up my battery to battery charger using 25mm2 cable and just used it for the other bits and bobs as I was confident it would do the job. I figured better safe than sorry - though I haven't tried carrying the power to my house yet! ::bigsmile:
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
You won't need any larger than 8.5sq mm. That will cope with 15A over a 5m run. If your circuit is less than 3m long a 4.0 sq mm cable will do. Termination would be an issue with larger cables; ok if you have the equipment.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Have been chatting to Sarah via PM.
( Hi Jon, hope you are good! You off skiing this year? Broke my shoulder last year snowboarding so giving it a miss this year as still waiting for op.
Tim
Ouch!
I bet that has curtailed the kite surfing too!:cry:
irnbru
irnbru
13,512
31,137
Glasgow
Benimar 264
11 yrs
The van is a 2010
Would this battery be suitable? I can get a USED one for £60 as opposed to £200 new.
Broken Link Removed
Think this question was missed. Please can someone
tell me if this battery would be ok as a replacement or a back up. The existing battery says 85. The seller is waiting on me picking it up but I'm just waiting on you guys to say if it would be any good or not.
I am getting the wiring redone on Friday hopefully.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Yes! US battery are a good manufacturer. You could have got the equivalent Dyno battery from justcarbatteries.co.UK for £70 less though!
However, make sure when you fit it, it is an area where it is adequately vented to remove the possibility of hydrogen gas build up!:Eeek:
It will be too tall to go under your passenger seat I reckon!
irnbru
irnbru
13,512
31,137
Glasgow
Benimar 264
11 yrs
I was thinking it would go under the single seat in beside the fuse box and the battery charger. Do I need to just use one or could I still have it linked up to existing battery which reads 850 not 85 as I previously said. As you can all gather I don't know much but the battery I'm planning on buying today says 135.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
It is best practice to have all batteries linked in parallel to be of equal capacity.
In practice, it matters not!
Link your batteries together, it will be just fine!:thumb:
TheBig1
17,604
43,079
as a general rule, second hand batteries are not worth buying. theres no warranty and you cant know how well the battery has been treated. this is what I would recommend and at £67.50 with a 4 year warranty is better value for a 110ah and delivered to your home next day too
Broken Link Removed
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Oops! Missed that bit.
I wouldnt buy second hand but I wouldnt buy a new leisure battery either.
irnbru
irnbru
13,512
31,137
Glasgow
Benimar 264
11 yrs
Problem remains
Thought our problem was solved but its still there. We have readings of 11.76 at battery and at heater and its still coming up with low voltage. We were watching the meter and never saw any drop in readings before the error code kicked in. I thought I read somewhere the voltage had to be higher than 10 for webasto to work.
Please can someone advise.
irnbru
irnbru
13,512
31,137
Glasgow
Benimar 264
11 yrs
Just bumping this up incase anyone can help and missed my previous post.:Smile:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
You have a poor connection or your wiring to the heater is too thin causing a voltage drop under load.
The fault in this case will only occur when the glowplug is being operated, drawing maximum current.
Get the supply to the heater upgraded or repaired and your problem will go away.:Smile:
I rewired my Dualtop supply on our Chausson due to low voltage faults. There has been no failure since.
Apr 27, 2008
11,842
14,067
Eastbourne East Sussex
Hymer low profile
Since 1972
11.76v without load indicates your battery has had it. It should read 12.4 -12.8v without load.
