AEMET NOTICE - Stormy weather in the Mediterranean areas
Information posted 1st December
From tomorrow, Monday 2nd, the stormy weather which has affected most of the country this weekend will reactivated as it moves towards the Mediterranean and joins the unstable flow of humid air coming from the east. This will cause large quantities of rainfall in Mediterranean areas accompanied by strong winds and rough seas.
Initially, the storm will move over the country towards the Gulf of Cadiz creating an isolated area of cold Low pressure (a Low at all levels of the atmosphere although less at ground level). Then, during Tuesday 3rd, it will move over the Mediterranean as a very defined storm lying at lower levels of the atmosphere and staying there until Thursday 5th.
This process will cause the air flow at all atmospheric levels to come from the east, carrying moisture from the sea. This moisture, although less significant than in Autumn when the sea is warmer, is still important as it rests within a mass of unstable air.
It is thought that this episode of adverse weather will start in the southeast of the country, and in the Strait and Alboran Sea, on Monday, bringing storms and downpours which will be heavy and persistent to the southern half of Valencia, Murcia and eastern Almeria. During Tuesday and Wednesday the stormy weather will extend over most Mediterranean areas of the country and the Balearics. The heaviest rainfall of this episode is expected in the southeast of the country.
Snowfall could also be significant in higher mountainous areas along the Mediterranean coast with the snowline coming down to around 1,200m.
Wind will also be an important consideration, with strong gusts which in coastal areas could reach 100kmh pr force 7 or 8 out to sea with waves over 4m high.
The instability will continue in the Mediterranean area during the following few days although with more localised downpours and lessening over this time. The rest of the mainland and the Canary Islands will not be affected although, from Thursday, a new Atlantic storm could affect the Canary Islands significantly.
For more info see AEMET (you can can change the language on the top banner "welcome" drop down. http://www.aemet.es/en/portada
