Watertanks? (1 Viewer)
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
Having just bought a campervan after having a caravan for a number of years the onboard watertanks are small so we going to increase the size of the tanks. The boss then asked where can we fill them? We are due to tour the highlands for two weeks and dont want to rely on campsite stopovers each night is there something I'm missing as I don't want to have to buy 4x 5lt bottles of water from the supermarket each day.
tonka
10,825
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
Be aware every extra litre of water is approx 1kg in weight. So check your payload and max weights. Could be a reason why you have a small tank. Or it could just be down to physical size of areas where they could place a tank.
19,695
51,876
uttoxeter
ambulance conversion
50 years
Better to find ways of using less water than adding more, in fact some folks travel with no water even if they have the capacity, just to keep the weight down.
The Simpsons
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
We are going to weigh bridge this week to check what payload we have. The onboard tank holds 15lt before the overflow starts running. For whatever reason the company that did the conversion put the overflow a third of the way down the tank. Will post image to show.
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
run the overflow up to the top of the tank to gain a third ive never seen a tank thats only 20 litres normally 50 ish min
The Simpsons
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
19,695
51,876
uttoxeter
50 years
15 lts no good for anything must be something wrong.
The Simpsons
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
It takes 14 lt or two watering cans before it hits the max line shown in image.
1,567
3,513
a
Well you are kinda stuck without modifying the van to take a bigger tank. Looks like you could definitely double the capacity in that space with a shelf and a different tank.
Failing that you could buy a filtration kit to suck up water from streams but it's not a quick process.
10,111
18,365
Renalt burstner
inside so they can claim its winterised i would get a tank fitted under the van unless your planning on skiing in wch case you could keep that one as well for cold areas
9,531
31,978
sleights
c class
Hard to see how that tank is secured but it looks dodgy to me ours sits on the floor in a steel surround that forms the rear seat base.
53,309
149,502
That looks ridiculous that strap will never hold in prang probably not even with an emergency stop.
I thought our last van had a small tank only 100lt, I used to carry 2 X 20 Lt containers as well.
Two wouldn't even get a morning shower with 15lt.
In Scotland most garages will let you fill up with water, just ask before putting any fuel in, if not go on to next one.
11,839
14,063
Fresh tanks I've had have always been 100L+.
Cant understand why anyone would put in such a titchy tank even our grey tank is 75L.
I had a brand new CAK tanks 50L tank in my garage for ages but swmbo finally made me get rid of it.
The Simpsons
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
It was convered by cheshire motorhomes conversion and a check of companies house shows them as dissolved. Getting quotes to have underslung fitted, but the tank is just held in place with a single strap. Getting the van weighed this afternoon to make sure the exact permissible payload. Hoping to go to harris and lewis the first two weeks in september so need enough volume to last a couple of days and hopefully find somewhere to fill up with water.
The Simpsons
The Simpsons
87
161
North Yorkshire
Van conversion
Newbie ex caravan
Back from the weighbridge and smiling. GVW should be max 3,500 weighed in at 2,860. Front axle max 1,850 weighed 1,520 rear axle max 2,000 weighed1, 340. Overall 640 to cover 2 passengers adding minus 45 kgs for half full tank fuel, gas tank was full and toilet flush minus 7kgs (based on 1 lt = 1kg) that leaves 400 kg for new watertanks camera gear clothes and food. Now to find someone in north east that has space to do work in next 2 weeks.
Thanks again all for your help and knowledge
