Water pump will stop pumping!
Hi Happy Christmas to everybody.
Need help, overnight the water dumped due cold weather . Pushed in the dump control in and half filled the tank. Turned water on all the taps, water was coming through hot and cold taps. But the only way I can stop the pump is to switch off the pump on the control panel.
Hoping can help?
Colyboy
meanders
Funster - Life Member
Ipswich, Suffolk
Eura Mobil Terrestra
Since 2004
It takes about 10 minutes for ours to fill the system and pump through enough for the pressure switch to operate. We need to pull hot and cold through all outlets including the shower and loo to remove the air.
Sunny South Shields
Frankia Platin i7900
Since 2010
Hoping can help?
Colyboy
Have you reset the truma dump valve by resetting the top and pressing the small button on the side? If you have done this then crack open all taps and shower slightly run until all air is out the system then close taps and the pump will stop if not you have a leak.
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Check the dump valve has really reset.Check under van no water is coming from dump drain.
