Hi, with the colder weather forecast I thought I should drain the Motorhome. Opened the valve for the fresh water and it drained away ok. Then flicked the yellow switch beside the water boiler and saw it drain away (looking at the external outlet) as expected. Also opened the hot water taps in the kitchen and loo - water stopped coming through the taps quickly but took a while to stop draining outside. However while no more water is draining the pump remains active. It’s an old van (2004 CI Carioca) so I doubt there’s any low-temperature related switch on at play here. I’ve double checked all taps are off, and had a look in the fresh water tank which is also empty. I’ve tried flicking the yellow switch, but pump is still running. It goes off (of course) when I switch it off at the control panel. Any thoughts chums?
