Exactly the Robles I had. Sorted nowHad the same with a Whale system last week. Turned out the winter dump valve to the hot water tank had been knocked and opened slightly and we were loosing just a little water through that. Opened and closed again sorted it. Something else to check.
had the same, filter not tight enoughWhen that happened with my pump, I discovered that the screw-in inlet filter needed tightening slightly..
Not so. Mine was due to pressure drop due to a faulty non return valve. Replaced it - no problems for 4 years.Definitely a leak. Check all joints for moisture,I use a piece of kitchen roll tissue to wipe each joint.
Check also the base of the taps where the flexi pipes screw in.
Happened to me on my first outing this year. I knew something wasn't right so looked at the pump and a small leak had started from one of the joints on the outward branch. It was a push fit T-piece. I released it - cleaned it, put it back but still leaked. Luckily a caravan parts dealer was nearby so hopped on the pushbike with T-piece in hand to make sure I got the identical match. Back to the Moho and Bob's your auntie. No more leak...Phew! I'm guessing the nightly frosts through April had perhaps damaged the seal somehow on the leaking T-piece. Even though the system had been drained for the winter, some water can remain at critical areas.....apparently.Hi guys
Every 5 minutes Shurflo water pump is activated/making a noise that lasts for only a second or two. Quite annoying! Is it a pump fault, leak or tap switch problem?
Any ideas gratefully received
Paul
Could also be the pressure release valve needs replacing.
Any update?Thanks everyone, checked connections whilst on site and all seem ok. Further investigation needed when home tomorrow.
