water pump coming on (1 Viewer)
brian55
16
4
Hi all me again Brian.
Peugeot boxer 2. hdi 2005 auto cruise starfire water pump unit is a posiflo model 3000-151-2201
The problem is the pump sometimes switches itself on without the tap switched on.
This van I am sure does not have switches behind any taps so works on difference in pressure etc.
There is square area on the top of the pump with a screw I think this changes the amount of flow any help appreciated thank you.
Jul 12, 2013
4,004
5,558
The City of Henlow
Adria Supreme
Since 1980
Plastic pipes as they warm up, expand slightly, enough on a previous van to occasionally allow the pump to switch on.
Feb 18, 2010
460
213
Had the same problem very small leak from pump body , changed pump for new one no more leak
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We had the same pump in our Swift, and the same symptoms, the pump ran for a second every couple of hours or so. No leaks in the system, so took the pump out and stripped it down. I could see no evidence of any leaks internally so cleaned it up and put it back together.
Still ran intermittently and got more frequent so I changed it for a Shurflo pump and had no more phantom pump running.
