I don't like things not working and it's not overly accurate but easier than looking in the tank.Doesn't help, but why bother... They are never accurate or dependable.
Same goes for the grey tank probes.
I'm with you on this, if it's fitted, it needs to work!!I don't like things not working and it's not overly accurate but easier than looking in the tank.
I was trying to remove it and slipped breaking the wires flush with the top.How, i what way, have you broken it?
Can it be fixed?
It may have a nut inside the tank that you need to hold whilst the sender is unscrewed.I was trying to remove it and slipped breaking the wires flush with the top.
I also can't get it off as it is just spinning and not unscrewing, I think I will have to cut the plastic nut off to remove it.
Unfortunately not.It may have a nut inside the tank that you need to hold whilst the sender is unscrewed.
You're right, it doesn't help.Doesn't help, but why bother... They are never accurate or dependable.
