WATER BOILER
Warwickshire, UK
Chieftain
Since 2004
Anyone help with this please ,Hooked up on electric all working fine switched the boiler on and woke up this morning to find water cold ! Switched over to GAS and that's ok hot water very quick ,I understand the fuse for the boiler is the same for the fridge and that's working fine so any suggestions please
I had that happen, after a lot of off grid camping in the south with very hard water. First time I used the electric element is blew. When I replaced it , it was covered in scale.
You can change the electrical heating element but it‘s not always simple, as boiler is removed for the process.
Your other option is just use gas, which is cheap if using refillable cylinders. Some motorhomes don’t come with the electric option, and just use gas.
Not sure what water heater you have but mine has a built in trip in case it gets turned on when the tank is empty to prevent the element getting burnt out. It has a reset button on the front behind a small plastic flap.
