Waste water tank (1 Viewer)
Mrboff
4
Marske by the sea
Auto quest 140
Hi I am after getting my waste water tank changed on my auto quest 140 motor home, I have rang different companies in the North East but no joy does anyone know where I could get this done, thank you
Jan 8, 2013
8,478
11,516
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Replace pipe with a new piece glued into tank with solvent weld.
See your local plumbing merchants
9,322
24,578
Derbyshire
Elddis Accordo 105
since 2014
Look at these overflow fittings and pipe on screwfix. 👍
561
1,318
France
Pilote G691 LCE
Since 1974
Does your existing tank have a large access hole in a position that would allow you to get your hand to the inside of the tank where the outlet pipe was fixed?
If it does you will be able to get a screwed fitting for the type of pipe suggested above that you could fit with the nut inside tank.
1,473
3,485
30 years
I am not a plumber, but do know there are fittings that can be installed in tanks without access to the inside. Look up Essex flange.
Geoff
