Waste water tank removal
Aberdeen. In. Scotland
Bessacarr E795. 2004 on
Since 2018
Hi all I have an bessacarr E795 and get no reading from the Sargent EC200 system re how much w/water is in the tank and wires from tank seem to come from the top of the tank which means sensor must go in from top which means removeing the tank to get to said item has anyone done this and do the bolts and or straps holding the tank brake ?
I removed the tank from my E560 to renew the straps, fairly straightforward as I remember. Don't actually bother with the level indicator just know how much is in there.
When it comes out the overflow, it's full on our's ;)
Yes OK but did the bolts holding it on brake as I am getting it done under warrenty and they are very long bolts and M/H is 2004 so I know to get this done after my hols if they brake as m/h will be out of action if dealer brakes the bolts and swift seem to take forever to get parts if at all as I had to source sender unit myself from Sargent a reconditioned part .
If the bolts break its not a problem, they're just bolts, 12mm as I recall. The originals are far too long, I replaced mine with stainless of the correct length.
