sean n maggie
got a warning light on the dash of my autotrail,,,and it wont start,,,anyone know how to solve it please....it is the padlock light...
Fiat Ducato 2008Model, year would help, but sounds like immobiliser...?
Have tried both keys, still the same thing ..Generally this means there's a problem with the key \ immobiliser. Basically the immobiliser is not recognising the key code.
Have you tried the spare \ second key?
If still the same problem it may mean the key\s need recoded.
Others with more info will be along shortly who may be able to help with the recoding side.
The bit from the X250 manual.
THE FIAT CODE SYSTEM
This is an electrical engine immobiliser system which
increases protection against attempted theft of the
vehicle. It is automatically activated when the ignition
key is removed.
Each key contains an electronic device which
modulates the signal emitted during ignition by an
antenna built into the ignition device. The modulated
signal, which changes each time the engine is started,
is the “password”, by means of which the control
unit recognises the key and enables to start the
engine.
OPERATION
Each time the vehicle is started turning the ignition
key to MAR-ON, the Fiat CODE system control
unit sends a recognition code to the engine control
unit to deactivate the inhibitor.
The recognition code is sent only if the Fiat CODE
system control unit has recognised the code
transmitted from the key.
Each time the ignition key is turned to STOP, the Fiat
CODE system deactivates the functions of the
engine management control unit.
If the code has not been recognised correctly, the
warning light turns on accompanied by the
related message on the display (see section “Warning
lights and messages”).
In this case, turn the key to STOP and then to
MAR-ON; if it is still locked, try again with
the other keys that come with the vehicle. Contact a
Fiat Dealership if you still cannot start the engine.
IMPORTANT Each key has its own code which must
be stored by the system's electronic control unit.
Contact the Fiat Dealership to have new keys (up to
eight) stored with the code.
Warning light switching on while driving
❒ If the warning light switches on, this means
that the system is running a self-diagnosis (for
example for a voltage drop).
❒ If the warning light stays on, contact a Fiat
Dealership.
The electronic components inside the key
may be damaged if the key is subjected
to strong shocks.
i have 2 keys, the main one with remote locking etc and a basic key,,,none of them will start the van..What other keys?
Just noticed on dash screen, its saying check transmission, refer to handbook...but i cant find anything about it in there....
will try that in the morning...Just try putting a jump lead from a good earth point on the gearbox/engine onto the negative post of the battery and try that.
in neutral with brake pedal downIs it automatic? if so is it in park or neutral with your foot on the brake?
will try this next week when i get back from holls,,,thank you,,,,Disconnect the engine battery terminals and touch the two disconnected leads together to discharge any capacitance in the loom. If you have an alarm BBUS (Battery Back Up Sounder) disable this first before disconnecting the engine battery. The owners manual will describe the process in how to disable the BBUS. If you have a B2B charger or the habitation batteries power the engine battery in any way disconnect the negative terminals, if there are solar panels disconnect the + wire at the regulator before disconnecting the hab batteries. Wait 10 minutes and then re attach the battery, live first then the negative terminal ( reconnect the hab batteries and then the solar if previously disconnected). This will reset the EMS/IPAC/Alarm and is sometimes all that is needed to reset the immobiliser. Arm the alarm and then disarm and then go through your normal engine start routine. HTH
tried that this morning,,still no luck,,,,but thanks for trying to help...Disconnect the engine battery terminals and touch the two disconnected leads together to discharge any capacitance in the loom. If you have an alarm BBUS (Battery Back Up Sounder) disable this first before disconnecting the engine battery. The owners manual will describe the process in how to disable the BBUS. If you have a B2B charger or the habitation batteries power the engine battery in any way disconnect the negative terminals, if there are solar panels disconnect the + wire at the regulator before disconnecting the hab batteries. Wait 10 minutes and then re attach the battery, live first then the negative terminal ( reconnect the hab batteries and then the solar if previously disconnected). This will reset the EMS/IPAC/Alarm and is sometimes all that is needed to reset the immobiliser. Arm the alarm and then disarm and then go through your normal engine start routine. HTH
