Wanting tow car (1 Viewer)
icantremember
8,262
17,179
Near to Watton in Norfolk
Hymer T-SL668
since 2005
75
256
chauson
Any tow cars for sale in northwest area ideally ?
Have you checked your Chauson is ok to tow. L bought a Chauson 774ga only to find it has a towing capacity of around 400kg I was well pissed off as when I ordered the van at the Nec I told the salesman that we would be towing a car and was not told of the restrictions.
Robbiechausson788
Jun 26, 2022
15
9
Rainford, Saint Helens, UK
chausson titanium 78
15 months
…..or look at towbars2towcars as they always have toads ready to go
Yer I’ve looked on there thanks . I have a fiesta for my job so was just looking at LNB and they do trailers to suit. Was thinking that if possible would be the cheapest option knowing it wouldn’t be getting used regularly. Thoughts ?
yer I’ve got a certified from the company that fitted the towbar as he said you needed it if going abroad 🤷‍♂️ Would of ideally got an A frame fitted to my fiesta st line x edition if I could find someone to do it.
DuxDeluxe
14,554
74,650
Planet Zog
A woosh bang van
since 2008
I’ve just messaged them thanks. I’ve seen fiestas before being towed and didn’t think there would be a problem. Maybe it was just the company in stoke that was unsure about doing it but they said it couldn’t be done.
Mine was a 1.6 diesel so quite heavy but the van could tow 2 tonnes. Not sure about the new model fiesta.
Sometimes better to give them a phone call
22,581
121,443
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
985
998
South Lincs....
Rapido 7095DF
20+ years. Previously Hymer B654 and Hymer S660 both c/w tow-bars.
You should check the VIN plate! It overrules anything a salesman might tell you…. 😏
DuxDeluxe
14,554
74,650
Planet Zog
A woosh bang van
since 2008
I assumed, wrongly , that we were talking about a cert for any toad as there is no requirement to carry anything relating to having a tow bar fitted to allow you to tow?
Perhaps we are talking cross purposes here…. Tow bars need to be type approved since about 2010, but you are right about toads in European countries. A big no
Minxy
31,933
63,468
E Yorks
Carthago Compactline
You won't need a certificate for the tow bar as it's not required here which is where the MH is registered.
As for a toad, you can't legally tow it in some countries in Europe so if you do intend to take it abroad a trailer will be needed.
46
34
Newcastle-under-Lyme, UK
Autotrail Savannah
I'm a relative Newbie
This is very interesting. We have a Peugeot 107 converted by Towbars2Towcars. The docs provided include a 'Declaration of Conformity', to 98/37/EC Machinery Directive, 2004/108/EC EMC Directive, 2006/95/EC Low Voltage Directive. Within the doc also EC Directive 98/12/EEC and C&U Regulations 15, 18 & 86A and issued Brussels and London. The pack also includes explanations of conformity in French, Spanish, Portuguese and German. The doc is signed 25/10/2022.
The pack also states that the tow car is for personal use whilst staying at a campsite and will be returning to the UK with the Motorhome at the end of the Holiday. Further it states that, under the EC harmonisation agreement any vehicle approved for use in any EC Country is allowed passage in any EC Country for a period of 6 months.
Ok, well the important factor is that just fitting an 'A' frame to your car is not sufficient. The car must be converted to, in our case weighing 850kg, braking applied via an electronic braking sensor in a proportional manner, to exceed 50% efficiency. A snatch wire in the unlikely event of detachment that will apply the brakes and all lighting required to be in place through the towbar socket hook up. A number plate of the towing vehicle to obscure the towed vehicles and a board with 'On Tow', with 2 reflective triangle. All this supplied by the conversion Company. At this years show they are pricing between £3500 and £4000 to supply the 'A' frame and do the necessary conversion on your supplied car.
Whether Brexit has altered this I don't know.
Incidentally if considering fitting an 'A' frame, go for the ones with the telescopic arms. It makes life so much easier when connecting to the ball. The arms lock solid after a quick pull forward.
11,703
13,626
Eastbourne East Sussex
Hymer low profile
Since 1972
The UK is no longer an EC country so the above stuff doesn't apply. It probably never did as A frames are not approved in the UK, merely overlooked.
46
34
Autotrail Savannah
The 'A' frame is legal and approved by VOSA in the UK providing the modifications have been done to the towed vehicle which is then classed as a Trailer. It is not now legal to simply strap an 'A' frame to the front of a car, as was the usual practice.
Coolcats
5,730
8,341
HymerCar Ayres Rock
That does not mean an A Frame cannot be used within the UK as A Frames are not required to have type approval, but reading between the lines its best that when using an A Frame the towing vehicle and towed meets the requirements of both Vehicle and Trailer this is .Gov's position on it
The same document states:
Use of A-frame outside UK​
The views expressed above are only applicable for the UK. We understand that these view are not shared in other European countries and we would not recommend use of an A-frame outside the UK without some investigation of the rules that apply in the relevant country. We are unable to comment on, or enter into correspondence on, the situation in other countries as this will be governed by their domestic laws, together with the Vienna Convention.
We would remind users that the views expressed above relate solely to the technical requirements for a motor vehicle when being used with an A-frame. Users should satisfy themselves that they comply with all other aspects of road traffic law that may apply whether the towed vehicle is viewed as a trailer or as a motor vehicle.
All of which is interesting comments
Coolcats
5,730
8,341
HymerCar Ayres Rock
The 'A' frame is legal and approved by VOSA in the UK providing the modifications have been done to the towed vehicle which is then classed as a Trailer. It is not legal to simply strap an 'A' frame to the front of a car, as was the usual practice.
There is no type approval for an A frame according to .Gov its a grey area where if you are fitting one make sure it meets Vehicle and Trailer regs
Minxy
31,933
63,468
E Yorks
Not this hairy chestnut again ... it is ILLEGAL to tow one vehicle with another in many parts of mainland Europe, putting an A-frame on does NOT stop it being a vehicle no matter how many things you do to make it more trailer-like. In the UK we can often do things like this unless they are specifically banned/unlawful etc but abroad it is usually the opposite, ie you can ONLY do it if there is some law/agreement/rule/permission which specifically allows it.
I'm just gonna go and make some 🍿 and settle down for the 'debate'.
985
998
South Lincs....
Rapido 7095DF
This is confirmation that you can’t believe everything the a-frame suppliers tell you, or the paperwork they give you.
a ‘Declaration of Conformity’ is NOT a certificate of conformity. They are NOT issued in London and/or Brussels, they are a self declaration that their product conforms. Sadly, it doesn’t.
98/37/EC Machinery directive specifically excludes vehicles and their trailers.
2006/95/EC Low Voltage Directive is only applicable to DC circuits between 75 volts and 1500 volts. (Not 12 volt systems).
Countries can (and do) have their own national laws regarding the towing of motorised vehicles. There is no automatic exclusion for 6 months or any other period. (See the previous comments ref. Questions for written answers in the EU Parliament).
There is no requirement for ANY signage, merely reflective triangles.
Their documents issued in other languages claim the a-frame is CE approved. In fact, none are, there are no standards for a-frames.
The paperwork is purely a marketing exercise. …. ….. 😡
985
998
South Lincs....
Rapido 7095DF
An a-frame has never been proven legal in the U.K. and is NOT approved by VOSA (which hasn’t existed since 2014).
There is no approval procedure for a-frames, either in the U.K. or the EU.
The only country I’m aware of that has a procedure in place is New Zealand https://nzta.govt.nz/vehicles/warrants-and-certificates/vehicle-equipment/a-frame-towing/ (though there may be others).
