Wanted English instructions
Bexley Kent
Given up Motorhoming
May 2019
Instructions for a UNI-T. UT210E clamp meter. Just opened it up to find that the instructions are in Ying Tong. I want to check the 12volt DC can’t seem to get the DC scale
Thanks David
Super Mikes were a little clearer to read. I am a numpty when it comes to electrics but I have set myself a task to learn the basics. Looked at evening classes but it would be around £1500 so that’s a no no.
Each value is for both AC and DC.
There's no difference between AC amps and DC amps..... Amps are amps.
Just turn to the scale you want and use.
For DC volts, just select volts on the circular scale and then press the blue button and toggle between AC & DC.
thanks you all your help is much apprieciated
This might be a good start
