Waeco crx50 fault
Discussion in 'Fridges & Ovens' started by Mick209, May 14, 2018.
  1. Mick209
    Mick209
    May 14, 2018
    4
    Ratings:
    +0
    Just after the winter, fridge was switched on and a popping sound was heard from the back. Now not working at all, and has been taken to a caravan garage,no voltage found running through it.
    I've contacted Dometic, as it was installed in the van I purchased, no warranty.
    They have given me links to places that might help but no luck so far.
    They have given me a parts place to contact.
    I'm thinking it's a fuse blown in the electric modular unit? However I wonder if anyone has any experience and better advice please.
  2. Richard and Ann
    Richard and Ann Funster
    Jan 19, 2014
    2,263
    Derbyshire
    Ratings:
    +7,749
    Popping sound from the back could be the compressor overload. Every minute or two you'll hear a "click - hummmm - pop"
    It's a bi-metallic strip That heats up when the compressor won't start and breaks on overcurrent. The overload eventually breaks for good. If it is this, you need a new compressor fitting so it's probably scrap :unsure:
  3. TeeMyob
    TeeMyob Funster
    Jul 18, 2009
    2,674
    Javea, Spain/Manchester UK
    Ratings:
    +3,113
    Where are you based?
  4. Mick209
    Mick209
    May 14, 2018
    4
    Ratings:
    +0
    Based in Cambridge, sometimes Peterborough way
  5. Mick209
    Mick209
    May 14, 2018
    4
    Ratings:
    +0
    Definitely just one pop, I'd guess it being fuse going?
  6. Richard and Ann
    Jan 19, 2014
    2,263
    Derbyshire
    Ratings:
    +7,749
    Usually that's compressor or fan motor earth fault. Just disconnect things one by one until the fuse doesn't blow. Start with compressor, you can pull the spades off it directly under the black plastic cover. (it's usually black plastic:D2)
  7. Mick209
    Mick209
    May 14, 2018
    4
    Ratings:
    +0
    It was blowing fuses on the psu. Went direct to ehu and the fuse blowing sound came from the back of the fridge. That was it's last sound
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
