Hi someone had recommended that I get an inverter fitted to motorhome and have recommended a
other option for a charger is a Stirling 40a battery charger. Installing a 200 ah lithium as an alternative.
cost is an issue as can’t afford the 1.5 k for a 3000 W one
many views would be great fully recieved
Victron Energy MultiPlus Inverter/Charger -12V 800W/35A
People have said it’s underpowered but the guy said it would work most things but also act as a shunt if on under powered hookup from 5 amp upto 10 amp using on board battery. And will act as a battery charger when on hook up. I’m guessing it won’t run hair driers and microwave. All other battery management is victron so would fit in with that. I also need to run a cpap machine which can run off 12volt but nice to have the optionother option for a charger is a Stirling 40a battery charger. Installing a 200 ah lithium as an alternative.
