DBK
My Victron 75/15 MPPT controller seems to have failed. Just in case I've missed something obvious here is what happened.
We stopped to do some shopping this morning and I noticied the Webasto control panel was showing a red light and a warning about high voltage. It then started to shut itself down.
The NASA BM1 showed 15.6 volts and 6 amps charging!
Leaving Mrs DBK to do the shopping on her own I climbed into the back of the wardrobe and disconnected the solar panels. Things and voltages then returned to normal.
With the immediate danger of damage out of the way I left things until this afternoon to re-investigate.
I've twice disconnected the batteries from the controller, reconnected them then the solar panels. Both times the battery voltage quickly shoots up to over 15 volts. I've double checked the battery voltage with a meter and it matches what the BM1 is showing.
I think the controller must have failed but if anyone can suggest an alternative I'd welcome it.
I'lI try emailing Victron to see if there is any way to reset it.
Suggestions where to buy a replacement in the Algeciras/Cadiz area would also be welcome.
