Victron do say that you need to fully charge your batteries at lease twice a month for the SOC to synchronise.
Best to use info from the battery manufacture for their battery.a question on the charged voltage though, is this specification found on the battery jargon sheet or is it just obtained from the BMV once the battery is fully charged?
Hmmm, just looked at the spec sheet and I cannot see a definitive figure?Best to use info from the battery manufacture for their battery.
As an example the Hankook XV110 battery was way different bulk, absorption and float voltages to batteries of a similar type and as such was not being fully charged.
Yes, when you disconnect the power supply, it re sets to 100% SOC automatically, regardless of battery state of charge. What are your settings, I can help you dial in more appropriate values, to prevent premature re synchronisation. I run two of these fairly accurate, within 1%.I did when it was first set up haven't really used it as it been sitting I the drive, although I did unplug it to reroute the cable, will it need resetting perhaps?
Hi Raul,Yes, when you disconnect the power supply, it re sets to 100% SOC automatically, regardless of battery state of charge. What are your settings, I can help you dial in more appropriate values, to prevent premature re synchronisation. I run two of these fairly accurate, within 1%.
You don’t need to sync it, dial in the values, and it will do it automatically when all are met. You can do it manually by pressing the two buttons, but, you need to be 100% sure you have charged it to full. That sync is just a reference point, until next sync will take place. Due to peukert, temperature, charge and discharge rate etc, it will drift. Hence the values need to be met to re sync to a new reference point. This happens if you give it a true full charge.It takes a fair bit of work to get the state of charge to read correctly, it took me over a week of tweaking the the settings to get it accurate.
You need to set the battery capacity to allow for age, deduct 2.5% for each year of battery age (and remember to do it every year).
Charger efficency setting probably 75-85% (default is 95% I think).
Tail current & discharge floor need setting for the type of battery.
Peukert exponent is probably OK at at 1.25.
Also when syncing you need to do it after the absorption phase but if the charger goes into float mode you need to leave it on float 24 hr before syncing.
Thanks for this, I'll give it a try in the morning, give the battery a full charge and report back!Reduce battery capacity to 125ah for now.
Charged voltage ( absorb assumed voltage in your charger) 14,4v
Discharge floor 50% is good
Tail current 1%
Charged detection time 30 mins.
Peukert exponent 1,4
Charge efficiency factor 80%
Try this settings and wach amps amorphous disappear to 0 before it syncs to 100% soc.
Thanks for a really useful thread and replies.Reduce battery capacity to 125ah for now.
Tail current 1%
Hi Raul,It will matter in the next cycle. If you set new values before charging then it would calculate different. As it was, it carried on with what it had, until you changed. After you changed, it was already in absorb, not much time left to go by. At least, it prevented a premature sync. How many - amps was left before it went to float?
Thanks for you help and sharing your knowledge, I'll monitor and report back, I just need to wire up the fridge as it's going to take weeks to discharge off the LED lights! That's this weekends fun sorted!It won’t be in the history. It’s only if you are around and notice amps left to put in before it drops in absorb. The only thing is logged, is the deepest and average discharge. First time I noticed this I realised the victron settings are generic and needs playing up to suit individual system. I noticed -15-16ah to go and it was charging under 10amp at the time. Five minutes later it reset to -0ah and 100% of charge. The battery still charged until sundown hrs later. The settings victron gives are not near enough time to consider full charge. Maybe this suits their batteries, I don’t know.
For now, monitor % soc and give it few days. The microprocessor still adjusts and learns the system. If after 4-5 days nowhere near then further adjustment will bring it closer. I always rely on amps to go rather than % soc. The amps to go are accurate true coulomb count. Where the percentage is a approximation.
What batteries do you have?On the suggested updated bmv settings I'm struggling to get the battery's to reach 100% SOC now on Solar top up.
I've got the compressor fridge only running, and that seems to draw 13A or so overnight, but the SOC is only getting back to 96 % -6A) by sunset. I accept the fridge will draw another 13A or so in the day during charging.
I find that hard to believe with 175W Solar during mid summer Bright / sunny days (albeit at 55N in Glasgow)
Any ideas
Raul , hmmm... I'm not sure these BMV settings are working for me.Based on the info provided I would try this settings. Not you do not want the bmv to reset to 100% prematurely, and if bmv says 96% I would trust its count.
Battery capacity 180ah
Charged voltage 14,4v
Charged detection time 15mins
Tail current 1%
Discharge floor 50%
Peukert exponent 1,35
Charge efficiency factor 90%
The agm,s are incredibly efficient on charging from 50 to 80-90% state of charge in bulk, the last 20-10% in absorb, not so. The same goes with shallow cycle, if you only cycle the top 20%, expect to pay in the inefficiency of absorb. For every 10ah used, expect to put back as much as 15ah to full.
