Victron bmv-702 (1 Viewer)
Deneb
1,598
2,334
Europe
PVC
I think the only way is to restore factory settings (press and hold both the SETUP and SELECT buttons for 3 seconds) and then reconfigure the unit.
andynkim
107
200
Mobilvetta K-Yacht 85
From the Manual
4.2 Functions overview
The following summary describes all the parameters of the BMV.
- Press SETUP for two seconds to access these functions and use the
+ and – buttons to browse them.
  • - Press SELECT to access the desired parameter.
  • - Use SELECT and the + and – buttons to customize. A short beep
    confirms the setting.
  • - Press SETUP at any time to return to the scrolling text, and press
    again to return to normal mode.
4.2.5 Miscellaneous ______________________________________________________________ 61. Software version (read only)
The software version of the BMV
62. Restore defaults
Resets all settings to factory default by pressing SELECT.
When in normal operating mode, factory settings can be restored by pressing SETUP and SELECT simultaneously for 3 seconds (only if setting 64, Lock setup, is off).
63. Clear history
Clears all history data by pressing SELECT.
Cheers Andy
