Hopefully someone can help with this one. I have a Fleurette Magister and yesterday the control panel showed 0 bolts for the vehicle battery. The engine starts ok and the across the terminals there is 12.44 volts. One of the connections from the positive terminal also shows 0 volts and I have 0 volts from the vehicle battery at the shunt (where all the fuses are located). See photo of battery terminals. It is the top one showing 0 volts. Is that a fuse next to the terminal? In which case maybe a fuse had blown.
I also have a problem with the fridge not working at all so maybe the two issues are connected. Any help/ advice would be gratefully received.
William
William
