Our cab battery is not charging sufficiently when we are on our long term pitch here in Benidorm.
We are not on hookup.
We have 2 x 125ah new leisure batteries charged by a 175w solar panel.
Our CBE 12v System is designed to charge the cab battery when the leisure batteries exceed 13.6v, however it seems that during the normal day not enough is getting to the vehicle battery and it slowly loses its charge over several weeks.
I run the engine for 30 minutes once a month which helps a bit, but I don't want to run it just to maintain the vehicle battery charge.
The cab battery runs the alarm system and the cab door foot well light which comes on and off when the hab door opens.
I have removed the halogen bulb from the door light to reduce the draw to a minimum, but I need to have the alarm system working .
Can I run a temporary fused cable from the positive of the nearby leisure batteries to the positive of the cab battery to maintain the charge? and if so what are the likely effects to the remainder of the 12v system.
Ed
Ed
