- May 10, 2020
- 715
- 2,308
- Hymer ML-t 580 4x4
- Getting there!
Battery Master Fitting
My power hunger Sprinter Van seems to drain its 95AH starter battery in a week or so of non-movement.
I have 200 watts of solar running through one of these:
to the 95A Starter battery plus 2 x 100Ah leisure batteries.
Battery1 and Battery2 are the starter battery and leisure batteries outputs.
When it’s sunny enough the starter battery gets a user configurable share of the generated power.
I have an alarm, electric assist close on the sliding door, dash cam security monitoring plus the MBUX and ECU bits of the Mercedes set up all drawing power from the starter a battery. The starter battery starts to show low voltage if left for more than week without an EHU.
I’ve acquired a VanBitz Battery Master so I can balance the starter battery from the 2 x 100Ah leisure batteries.
I was just have a quick look see where the best place to fit it would be and wondered whether I can just wire it across the battery outputs on the Solar Regulator as that is the easiest bit of the system to get to.
Thanks in advance ..
