we have a 2018 autotrail with an external aerial point. How do you make it pick up the external aerial as opposed to the Maxview roof aerial. Any advice gratefully received. Thanks
It would seem not Andy as they asked how to make the external point work.Are you sure it’s not permanently connected?
So aerial and external are joined before booster.
The DTV setting on the TV will, almost certainly, be the roof aerial. Have you tried the satellite setting on the TV as I believe the external input point is supposedly to connect an external standalone satellite dish, could be wrong though (well, probably)! If it is for a standalone sat dish don't think the satellite tuner built into the TV will pick up terrestrial TV channels. Also surprised it's a coax input (if for sat) as they're usually "F" type connections.Thanks for all the suggestions. Our van has a permanent fixed coax input in one of the external lockers and so you plug the coax lead to that and the camp site post. The Tv is flip down so no alternative coax cable to swap in. Similarly by the Maxview booster there are no wires to swap over. I am assuming there must be a switch somewhere but beggared if we can find it. Options on the tv are Dtv, satellite, av, dvd, hdm1, USB.
