- Jan 14, 2021
- 40
- 34
- 5W!b*ab3K#
I have just bought an un-regulated 21mm Quick-on adapter and tail that lets me use Calor Butane in my van. It connects into the bulkhead regulator so to go back to Propane it needs a bit of pipe work but it seems to work well.
It was a bit of a tight squeeze getting the bottle in (I had to move it to the left side of the locker as the lock fouled on the cylinder on the right!) but at least I don't have the worry of getting stuck without gas.
If you use a regulated connector, this doesn't give the bulkhead regulator enough pressure to work. Bought from gasproducts.co.uk Part number HA328
20" Propane/Butane Gas Pigtail 21mm Clip-on x W20
High pressure black hose to (and marked) EN 16436-1 Class 3. 6.3mm i.d., 16.3mm o.d., 30 bar working pressure, 90 bar burst pressure. A self adhesive advisory label is attached to every hose.
www.gasproducts.co.uk
