Used van suitable for winter continental use? (1 Viewer)
Marmottefarcie
Don't own one yet
Newbie
I am researching our first motorhome purchase and could benefit from the collective wisdom of the forum.
I am looking for a used motorhome that would be suitable for use in the Alps in the winter.
From what I can gather, some of the continental vans are designed with this type of use in mind (double floors, insulation etc).
Can I assume that an 18-20 year old Rimor SuperBrig or a similar aged Chausson would be ready for this type of use or do I have to look for models that have been winterised specifically?
Thanks for your help & advice
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
Hi and welcome to mhf
There are quite a lot of vans made to be used in colder weather , we will start the list with nieshmann+bischof ------ ours is a flair
You will find subscription to the forum will be an incredible investment!!!!!!
Nigel & Pamala
11,144
17,741
HYMER B644
7,228
20,071
Barnard Castle, UK
Concorde Concerto
See my post below.
The First two motorhomes were double floor.
The La Strada, not so.
The Hymer, no double floor but the Fresh water is inside. The external Waste did not freeze even at -17c
https://www.motorhomefun.co.uk/foru...to-survive-winter-with-no-burst-pipes.156170/
Look down for my post, It quotes -7 on the Hymer. But since been down to -17c
Good luck!
Surely Trev the external Hymer waste tank has a pipe running to it straight from the Truma, our 2 older Hymers did.
8,477
20,122
Shrewsbury (sometimes)
N&B Clou Liner MAN
Welcome to FUN and congratulations for deciding to go the used route at least for your first purchase, most people you talk to have been through at least 2 or 3 mhs before they found one that suited them.
However at the risk of wrath from owners Rymor and Chausson are OK but neither of them are any where near the top in the quality stakes and I'm pretty sure there are better choices you could make for your intended use. At this sort of price level you could pick up an Old N&B/ Hymer/Eura/RMB/Rapido etc etc ( note the MB bases ones tended to be single floor). There are different levels of 'winterisation' but its pretty easy to check if they are double floor - if you can see the waste tanks underneath then they re not.
hth
Jon
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
hth
Jon
My van you can see waste tank but it is double floor in as much as 50mm of insulation sandwiched between the ply on the bottom/underside and interior van floor
138go
3,276
14,613
Carthago 138
Since 2001
Laika .. We have central heating round the water tank and plenty of insulation elsewhere including the floor.
8,477
20,122
N&B Clou Liner MAN
IMHO that isnt a double floor because there is no space in between, But lots of variations, you pays yer money.......
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi marmot
Welcome to the forum
loads of helpful advice from people here.
We have been going to the alps for winter for the last 8 years
First thing
Double floors are great
However they still have frost pockets within them
Once you decide on a van to suit you
Ensure that the heating system blows some heat onto the water pump area.
Also best to let your grey waste run out into a bucket
depending on the van the drain taps can freeze solid
so you can't turn the tap to let the water out when its full.
The alps are great. But a cold snap of -15 degrees at
night can turn into a cold period where the temp drops to -25 at night and never rises above -15 during the day
Any van can struggle so be prepared to with some tools and spare bits.
and lots of propane gasit's great fun and other motor homers are often around to help
11,722
13,698
Since 2013
Winter proofing isn't just about a double floor, it needs more design than that. Both my European mohos (Adria then Hymer) made sure that the heating pipes (or ducts on the Adra) ran next to the water pipes and toilet as well as around the water and waste tanks.
2,175
2,805
South Somerset
Carthago C-Line I 50
Since 2009
Our Carthago has a double floor with all services between the floors being well protected and kept nice and warm by the Alde system. It copes very well in cold weather.
Puddleduck
12,378
43,949
Scottish Borders
Without at present
On and off for many years.
Some Chaussons are "winterised" some are not. The Welcome spec is better than the Flash. I don't know if the new Titanium spec is better than both or not.
Our Adria has heating pipes round the waste tank and in the cassette locker. It was very toasty when we were away in it last weekend :)
bobandjanie
8,158
15,785
Javea, Spain
Pilote V600g
Hi, we had a Eura mobil good quality German motorhome everything inside the double floor, more than capable for winter use, we were down to minus 20 no problem, but we are warmer climate people so never made a habit of it. :xdoh: :xrofl: Bob.
1,939
5,683
Sussex
Since 2010
I guess the budget is limited as you are talking 18 - 20 years old.
My van is 18 years old and survived in Switzerland this year, I did spend most of the time wondering how much anti freeze was in the engine!
