Jim
Ringleader
jim submitted a new item
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
There is a really useful free app, both for Android and Apple that gives you all this and a lot more, current tax and mot status plus you can add your own vehicles into "my garage" then set up reminders for tax and mot on them. Its called vehicle smart and well worth downloading.
D.
Thanks and the simple version is free..... now got all our vehicles on it.There is a really useful free app, both for Android and Apple that gives you all this and a lot more, current tax and mot status plus you can add your own vehicles into "my garage" then set up reminders for tax and mot on them. Its called vehicle smart and well worth downloading.
D.
I just looked up an old V8 Lanny I bought new in 1986 and sold it in 1990. Broken Link Removed
Seems it went on till 2005 as that was its last fail. It only did 118,000 miles (at 8 to the gallon on a good day Clearly it wasn't loved much after we sold it. Well not undersealed anyway
- Reason(s) for failure
Offside Headlamp aim too high when the centre of the headlamp is above 850mm from the ground (1.6.B3)
Offside Headlamp aim beam image too far to the right (1.6.before)
Nearside Body has a sharp edge caused by corrosion (6.1.C.1)
Offside Body has a sharp edge caused by corrosion (6.1.C.1)
Nearside Track rod end ball joint has excessive play (2.2.B.1f)
Rear Tie bar/rod has excessive play in a pin/bush (2.4.G.2)
Nearside Rear Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Offside Rear Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Nearside Rear Brake pipe excessively corroded (3.6.B.2c)
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Front Exhaust system not adequately supported (7.1.1)
Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Nearside Rear Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
