Urgent help, advise needed asap
Notts
since 2000
URGENT. Help, advise needed asap.
So I have arranged to drop my MH off at Armitages today for work to be carried out Tomorrow.
I was told to ring the office number and the call would be diverted to someone on call, they would give me a gate code to gain access and leave the MH.
I have called number No answer. Luckily I'm still at home.
SO. does anyone know the procedure to gain access or if there is a contact number on the gates?
Use the universal key that’s called bolt croppers 🤔😊
Apart from that I’ve no idea
obviously the above is not a serious suggestion 😉😊
I've no idea where Armitages is - could you look on street view to see if there's a board with info on the gates?
Is there an email address?
I'd try ringing again in a little while.
Hope you get sorted.
Is it Armitage trailers & towbars? Have you tried emailing, or ringing the numbers on the website? Says it doesn’t open until 8am tomorrow.
Emailed and rang several times. Had been prearranged. To ring when I arrive
Unable to find a mobile number, pleased I haven't driven up there yet
Have you called both numbers?
01977 607155
01977 607157
The yard is home to several businesses so one of the others may be open. Look on google earth and see if you can see any phone numbers for one of the others.
Looks like a yard within a yard. Other businesses are closed too.
Looks like an early start for me tomorrow and some time off work.
I suppose there could be a note / number left at the gate when they are expecting someone :unsure:
Must be filling you with confidence in the job ?
Thanks. left hand not coordinating with right hand was the issue. Where are you in West Notts
Not far from Kirkby, I didn't realise you were in Notts as well! Where are you when not sitting outside locked gates?
