Urgent advice needed "Gaslow" (1 Viewer)
JJ20
250
561
UK
Since 2016
Hi everyone
I'm currently in spain and just filled up lpg at a repsol garage for the first time since being in spain and gas is now leaking out the side of the main hose in next to the first Gaslow bottle, it's leaking and crystallising....I will add a pic for you to see, I called Gaslow and they wasn't too helpful to be honest, I'm sat in the repsol garage not knowing what to do so please any advise is great. Thanks
TheBig1
17,611
43,139
looks like its rusted through and leaking. should stop in a few minutes as the non return valve will keep contents in the bottle. just the remnants of liquid in the leaking pipe. it needs replacing before filling again but if the non return valve is ok wont affect normal use
suavecarve
7,541
38,932
Surrey/Hants
Rollerteam 685
July 09
THIS IS NOT A DEFINITIVE ANSWER,
But i wouldnt over worry about it. Looks to me that you have potentially overfilled and the pressure is releasing at the weakest point. When the pressure goes down it wont leak out.
Potential courses of action (if i am right) is to reseal the weak joint. Check you are only filling to 80 per cent. Or only fill to less than 80 per cent where pressure wont cause this issue.
Somebody might be along soon with a better answer though
TheBig1
17,611
43,139
oh and not being condescending, DON'T TOUCH the pipe till it has warmed up
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
I know nothing about Gaslow - I have the Alugas bottles fitted... But!... Would have thought that there would be a non-return valve - at that end. It would seem a little daft to have the flexi pipe under continual pressure - in case of rupture.
My logic would be to tap the brass fitting - in case such a NR valve has somehow stuck!
Other than that - I await someone who knows the system to give you advice in the hope that you can sort it quickly
J
JJ20
250
561
UK
Since 2016
Ok thank you mate, a big sigh of relief. Gaslow said they can send me a pipe out but we have no idea where we will be and we are using aires, do you think I could get that pipe replaced in spain? Cheers
TheBig1
17,611
43,139
sourcing the pipe in spain may be tricky but its easy enough to replace diy
Sep 28, 2017
87
24
Audenshaw Manchester
Compass 180 Rambler
2017 Just started as Retirement looms in August
Type myLPG.eu in your Browser it gives you all the dealers in Spain and beyond
Hope that helps
J
JJ20
250
561
UK
Since 2016
I just want to say Louise from Gaslow could not have been more helpful, she sourced me a replacement pipe in spain in the end and covered the cost too "AMAZING" the first phone call I think Gaslow wasn't too sure what I ment but after more communications and pics they sorted it. I'm really impressed so thank you Gaslow.
Oct 29, 2008
5,065
5,926
West Yorkshire
PVC
since 2008
Certainly not definitive. If you have overfilled it means the 80% cut off valve has failed, and if you use your gas inside the van you will end up with liquid gas coming through.
If thats the filling hose I would presume as other people have said its just the residue from the fill so should stop after a bit.
I am not qualified to advise what to do other than keep any ignition sources away from your van
Badknee
7,407
412,376
notloB
Vantage Neo
Living the dream.
I'm thinking that if that pipe that is leaking goes from the fitting on the bottle comes from the outside fill connection it might be under tension and has caused a leak where it goes from rigid to flexy. If this is correct is there any way to reroute the pipe to release any stress perhaps?
Jan 3, 2008
3,337
5,356
Pakefield, Lowestoft, Suffolk, UK
Looking
Overfilling may cause higher pressure than usual but wouldn't the regulator stop any liquid gas passing through it, after all it is there to regulate the pressure. I don't know if this is the case, just wondering. Perhaps someone will be along who does know. In any case the issue is not so serious as first thought and a new pipe will cure it.
funflair
19,320
30,131
Guisborough
MORELO palace
since 2012
I have read that you should turn off your bottles while filling to avoid over pressurising the regulator, and it seems to make sense. My understanding is that the leak is on the filling side of the system so the ice crystals will have built up as the pipe leaked as it was filling but should sort itself out once the fill has stopped and the pipe has emptied itself, But yes it needs sorting.
Martin
funflair
19,320
30,131
Guisborough
MORELO palace
since 2012
I do agree with what you say and yes the pipes do look a bit rusty but I thought that genuine "Gaslow" were Stainless Steel?, you can see that the other ones are plastic sheathed and have "Gaslow" markings and they are also SS.
Martin
Minxy
32,629
66,498
E Yorks
Carthago Compactline
Martin
The 'faulty' pipe does look a bit suspect to me too as the end doesn't match my genuine Gaslow pipes from when we got our system back in 2009 .... I'm wondering if for some reason this pipe was used instead of a Gaslow one when the system was installed.
Dec 12, 2010
5,407
21,548
Cumbria
since 2011
Just noticed that too Minxy, no plastic sheathing on it either and looks to be leaking from the crimped ferrule, I wonder if it was a bespoke one ?
J
JJ20
250
561
UK
Since 2016
Thank you so much Louise at Gaslow, we finally reached Almeria and picked up our new Gaslow pipe, you saved our travels haha.
funflair
19,320
30,131
Guisborough
MORELO palace
since 2012
The crimp has failed where the hose connects to the spigot.
Replacement is the ONLY safe option.
I think you will find that these hoses are fully welded and it will be the stainless liner that has failed, same result though and it needs (and most likely has by now) replacing.
Martin
J
JJ20
250
561
UK
Since 2016
That Gaslow hose I just got today came with a 15 year warranty :)
