- Apr 18, 2021
- 182
- 659
- Sunlight Cliff 540
- Since 2008
My PVC has a Thule electric step that works via a switch on the bottom rear of the B pillar. If I turn the ignition on with the step extended, there is a loud buzzer that reminds you that the step is still extended, that ceases once the step is retracted.
I am aware that different specifications of the step allow the step to be retracted automatically once the ignition is turned on. I am also aware that this is achieved via a relay, somehow wired in to the ignition circuit. The relay plus wire terminals are available to purchase from Thule.
My question is: Has anyone done a DIY upgrade of fitting this relay to achieve auto retract of the step as outlined above? If so, how easy is it to achieve? (before I consider doing it myself.)
I'm assuming (big assumption on my part...) that as there is already a feed to the ignition on my current setup, it could be a 'simple' upgrade, perhaps even 'plug 'n play?'
