8
82125
Hi, I have a secondary solar panel that was fitted already when I bought this van (see photo).
Its pretty big, but can only guess its rating (150ish?).
The controller for it is faulty and only ever puts charge in to the starter battery on output 2, it never switches over to charge the leisures on output 1.
The controller is a PWM STCC10 (which states up to 150w/10a) which supports my guess the panel is around 150w or less.
STCC10 link
Am I right in thinking I can just swap out the STCC10 for a Voltronic MPPT 165 Duo? (165w/10)
For £100 it makes sense to have this panel (what ever wattage it is) adding to my leisure bank.
I also had a new 480w panel and MPPT fitted since the photo was taken that charges just the leisure batteries. I wanted to make sure it will be ok to fix the issue with the PWM by replacing it for an MPPT, and then both panels will charge the leisures and still put a 1a trickle to the starter.
1. Would there be any conflict having two controllers charging my leisure batteries (lead-acids)?
2. As long as I do it at night time, can I just install the new Voltronic without disconnecting anything else (disconnecting the panel first and reconnecting last)?
STCC10 link
