- Nov 16, 2015
- 130
- 553
- Malibu 600 DBK
- Years of Caravan, now got our new Malibu PVC
I recently updated the maps in the inbuilt Uconnect 10 in my 2024 van, and thought that the procedure might be of interest to others.
First you have to go to stellantis.navshop.com/#/downloads
Select Fiat Ducato, and the only option is Uconnect 5, choose this as maps are the same.
Download the Europe map, it will take ages, but eventually you will get a large zip file. Unzip this to a folder of your choice and you will find 7 large files and 3 small ones.
Next get a usb stick of at least 32GB, I used a 64 GB, it must be empty and formatted using FAT32.
Copy the 10 files directly to the stick, not in a folder.
Go to the van, switch on the ignition, and insert the stick into the central usb port under the heater controls.
It will ask you if you want to update, answer yes and some other questions, then the download will begin, it will take nearly an hour.
A couple of times the ignition switched itself off, but I simply switched it on again and the download continued to the end.
I have heard that you need to leave the engine running to force the ignition to stay on, but I was not going to leave the engine ticking over for an hour. Also some say do it during a journey, but I found that as soon as the van was moving the download stopped.
Anyway, my method worked for me, and I now have the latest software and maps dated 29/07/2025.
