Under bench aircon (1 Viewer)
jordano
170
8
blackpool
Triango CI Cipro55
3 years
we are a little tight on the roof and thought about putting the box type aircon under the bed space is anyone using this type and if so how do you rate them?
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
Be wary of putting under bed , as you may want aircon on to sleep !! Ideally aircon should be high , to take in the hot air (rises) and put out cold to sink down .
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have Truma Saphir units, they are not very efficient, nothing like the roof ones we had before. But if that's the only option then that's your choice.
eddie
8,157
41,266
Taunton Somerset
RV
since 1989
Badly! We won't fit the Dometic ones and the Truma one factory fitted on our last European motorhome was laughable as well
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
No room on the roof for proper aircon maybe the bix unit is not a good idea can anyone recommend fans that will fit into the standard roof vents maybe fit two
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Dometic do a roof one that incorporates a roof light and could replace an existing roof light?
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
Dimensions of external unit:
1008 x 660 x 248 mm (L x W x H) Truma Aventa 2400w ?
Mounts over existing roof vent
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
That’s what we wanted but there is not enough space for the top unit length is ok but one side on the vent is only about 90mm from our solar panel
Oct 2, 2008
4,471
7,956
Salopia
Duro 6x6 Overlander
since 1968
Cant you re-site the solar ?
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
No it’s pretty busy up there see pic
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
It’s tight up against the rear roof vent looks like it will have to be a couple of those turbo roof fans
Jul 29, 2013
9,071
18,520
Salisbury
Hymer B678DL A class
since 2011
Would the panel not go crossways at the front?it looks like the cable would be long enough and you wouldn’t need to make any new holes.
jordano
jordano
170
8
blackpool
Triango CI Cipro55
3 years
No room at the front big roof vent there
Jan 19, 2014
9,390
24,770
Derbyshire
Elddis Accordo 105
since 2014
You need a split system where the outdoor unit is separate and can be installed elsewhere. But the only ones coming up on Google are "Cool my Camper" or of course house ones. Perhaps the manufacturers are missing a trick (n)
Jul 29, 2013
9,071
18,520
Salisbury
since 2011
Cool my camper have some good reviews and look like it averages 6 to 8° lower temps (y)(y)
Jul 18, 2009
11,185
17,825
HYMER B644
Hi,
30 years in the RAC BUSINESS ( not the AA’s competition).
I fitted a trauma compact to our 6.5m Hymer.
It’s brilliant. Quiet (sits under Pullman in lounge). Efficient and far prefer it to the roof mounted units.
I did detail it on here somewhere.
TM
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
View attachment 242462 View attachment 242463 View attachment 242464 View attachment 242465 View attachment 242466 Hi,
TM
I see you have fitted some kind of screen over the one of the external vents, is that the outlet or the inlet? I have fitted the exhaust silencer box to mine but still get a bit of a roar from the exhaust vent which can be heard on the next pitch. As to their efficiency I have been rather disappointed with our 2 units and as an expert I would appreciate any comments on best practice install which you have identified with them?
Jul 18, 2009
11,185
17,825
HYMER B644
H
Hi,
It is a Toyota Pollen Filter fitted to the inlet. This will stop all the crap getting sucked into the unit. Truma Should have thought of that and fitted a removable one.
I think the best place to install is away from the main sleeping area. Usually, somewhere in the middle.
Even with Domestic A/C Systems from the likes of Daikin, Mitsubishi etc make some noise. But I do find the rooftop units resonate a lot.
We kept ours on with all the blinds shut in St. Tropez last summer, it was a godsend.
TM
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
Just been looking at your van on the picture you attached.. Turn the solar panel sideways so it is installed between the back of larger front roof light and the one I am assuming you were intending to install the aircon to behind.
A Dometic freshjet 2200 will literally not overhang any further foward than the existing 40x40 roof light you have installed currently. All the overhang of the aircon unit is overhanging the rear so it would fit. the only thing you may need to do is move your satellite system back a little, or by the picture it does look like an Oyster system so you adjust the lowest pivot able swing on the control panel in the hidden menu (speak to Oyster) so it would not hit the aircon and simply swing over the top of it whilst searching..
