Tyres . . . . . . . .again (1 Viewer)
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
Need to replace front tyres but the rear having done around 20k miles still have a good depth of tread left but they are have been on the van for 5 years.
Would you change them or run them ?
wasp
1,724
18,180
Warsop
None gone caravannin
I would say depending how much you value your van, and your well being go for the set, only you can decide, but I would(n)(n)(n)
Jaws
23,832
72,343
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Simply inspect them.. Are the walls cracking ?
Look between the treads and make sure there is no cracking there.. Chances are, if they are decent tyres and those those bloody useless Mich Camper things ( I think they make them from cardboard and marbles ) they will be fine
Frazzle
93
62
maidstone kent
09 AutoSleeper Berkshire
im a newbie
We bought our MH in May this year tyres looked new done 15000 miles i checked the date a few days ago and they are 9.5 years old 1 year older than the MH, so i got in touch with Continental tyres spoke to a chap about what to replace them with on at the moment Vanco Four Seasons i told him the old ones were like new and he said if they are in good condition leave them on for a while longer he went on to say that you read about 5years old replace them but there is no law stating how old a tyre must be. So are leaving them on at the moment, i have bought a Tyrepal monitoring system for a bit reassurance
Oct 15, 2011
4,127
11,108
Not Glasgow
Carthago chic eline
Since 2011
Here is a picture of a 10 year old tyre,plenty tread but it just came apart.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
You say they've been on five years, but how old are they?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
I go every year to my local tyre company and they inspect them. I changed at my insistence at, 11 years old and still plenty of tread.
Rob and Val
1,906
2,677
Lincolnshire
Talbot Compass Calypso
Since July 2010
Old tyres are usually OK if you are not going at any speed but on the motorway, as soon as they get hot, be prepared for a blow-out.
kelpie
563
420
Glasgow
Bessacarr E745
3 years
Read somewhere the two worst cicumstances for tyres are the "lack" of use means they sit on the one point for long periods , and the uv rays in sunlight. By my reckoning ,here in Scotland, I only need to worry about the lack of use bit:D.
Until I got interested in mohos I couldn't have told you that tyres could "go off", even with low mileage , when age comes into it.
John
Lenny HB
53,315
149,507
On the coast in West Sussex
Hymer B678 DL
Providing they pass a good inspection they should be fine until at least 7 years old (check the manufacturing date on them). As you keep your van in a barn out of direct sunlight so even better.
If they are OK I would put them on the front and fit the new ones to the rear. Always advisable to have the best tyres on the rear, also the wear to time ratio will be better so you should wear them out before they get too old.
Musicboy
191
182
United Kingdom
Rapido 7096+
fulltiming since 2003
As most know ... its not the tread (which may look healthy) it's the walls of the tyres which count ... thats outside & nearside Personally I changemine every 5 years . Max mileage 4000 & tour at 60mph ....Always check tyre pressures too ... Peace of
mind ...
I've had two blow out years ago on RVs , thankfully on rear tyres ... so able to control vsn to a controlled stop . Lucky ... Front blow out will almost certainly take you across or off the carriagway .... Nasty....
Frazzle
93
62
maidstone kent
im a newbie
OK you persuaded me ill change them before we are due to go away next thanks for your replies
Minxy
32,623
66,459
E Yorks
Carthago Compactline
If they are okay with no problems then keep them on so long as 5 years is the age rather than another couple on top as tyres can sit around for a while before being fitted to vehicles - check the date codes.
We've had to replace our 2 front ones due to damage caused on the atrocious roads in Italy last year but fortunately they didn't have a massive amount of tread left on them. We just bought some more new ones via Ebay at £105 each delivered - they've got a 2016 manufacture date but that doesn't worry us at all as we average 12,000 miles a year in the camper so wear them out before they need age-related replacement! :D
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
4 year's old and this happens complete blow out no warning. This week in Portugal. 26000 miles on the rear.
