- Apr 30, 2018
- 1,985
- 4,399
- Adria Matrix 670DC
- Motorhoming since 2018.
I recently fitted TyrePal TPM kit to the MH. For some reason the temp warning alarm on 1 of the front wheels is flashing and sounder is going off.
Could the problem be that I have not altered the 70degrees factory default setting when I installed the kit.
I have trawled through Google and can not find anything relating to tyre temperatures. I was therefore wondering if any knowledgeable people on the forum there might know the optimum temperature for these tyres Michelin AGILIS Camping 225/75R16CP – 116Q.
I've set the pressures thus; 65psi front and 80psi rear. The max GVW is 3850kgs if that make any difference, I would say we normally run with between 100 & 150kgs margin to spare
Thanking you in anticipation as always.
