If you search Tyrepal discount you should find it, code still works I ordered another set a couple of weeks ago. Then go to the Tyrepal site and enter code at checkout.That sounds great thanks. Will order a solar one as these seem popular. I assume this has an alarm in the event of a Puncture? How do we order to get the fun discount.? Thanks everyone.
Discount code on post #141 https://www.motorhomefun.co.uk/foru...s-20-discount-code-for-funsters.194219/page-5That sounds great thanks. Will order a solar one as these seem popular. I assume this has an alarm in the event of a Puncture? How do we order to get the fun discount.? Thanks everyone.
Just ordered mine, use discount code MFRVOC20TPThat sounds great thanks. Will order a solar one as these seem popular. I assume this has an alarm in the event of a Puncture? How do we order to get the fun discount.? Thanks everyone.
Agree with that - a "wake up" function for the sensors has been suggested to TyrePal several times previously but don't know if it is viable.I use this model and it works well and saves a lot of kerfuffle getting the hub caps off and checking each tyre with a gauge. The only way I think it could be improved is for the system to work when the van is staionary before you set off. It only works when you have been moving for a while, which means you can't check it before you leave after the van has been standing for a while. If I'm going on a long trip, I have to take it out down the road and back to my drive.
Yes, our pre-solar display sits in the front corner of the vacant upper-din space in the centre of the facia (we only have a standard digital radio in the lower din slot).I have the solar one, only problem I have with it is that it is difficult to read in daylight but, of course the alarm will still work. I think that the older, non solar type with the mono LCD display may be better in this regard. I have been surprised how well my tyres hold their air, over a year with no movement, and yes the sensors are working, the pressure goes up as the tyres warm, either by driving or the side of the van in the sun!
Yes, it's pretty basic stuff so easy enough to do yourself.Thanks everyone, all comments are so helpful. Just looked at their website and I see they offer a set up service. Is this needed or is it simple to do yourself. Thanks. Jeff
Also ensure VERY small o'seal in cap has not fallen out or damaged... main cause for leakage.One thing is make sure when you screw the sensor on to the valve you spray some leak detection fluid and check closely for leaks. They have been known to not seal correctly and let air escape.
Takes 5 minutes to unpack the box and sort out the various bits, 10 minutes to read the installation guide and put the supplied batteries in the sensors screwing them tight with tools supplied. Once at the vehicle turning on the monitor first it took me a further 15 minutes to remove old Chinese ones I had, add a dab of copper grease to the valve thread and lock nut and then fit each of the new ones. They are pre-registered to the monitor unit (set of 4 only) so come alive and read on the screen as soon as they sense pressure. The reading comes up in less that 4 seconds per sensor as you add them one by one. Go round with soapy water and check for leaks and tighten up locknut and away you go. The monitor fits to the dashboard with a re-usable sticky pad supplied in the kit.Thanks everyone, all comments are so helpful. Just looked at their website and I see they offer a set up service. Is this needed or is it simple to do yourself. Thanks. Jeff
Yes a very big plus and the only company doing this that I can see. I did have a problem with one sensor failing prematurely over the years and on contacting their customer service line they replaced the sensor FOC and sent me a pack of spares with their compliments. Absolutely all components of their various systems are readily available as spare parts and they deliver within 24-48 hours if ordered during the working week.Worth noting that a big plus is the company has a web site where spares can be ordered. Just ordered replacement rubber boots (50p for the set but £3-00 p+p!).
