Tyre Inflator (1 Viewer)
rich g
480
855
Worcester
A/S Warwick
since 2013
I'm looking for a good tyre inflator bought 2 off Halfords with the screw on adapter to the tyre,and by the time i have screwed it up i have lost half the air.
I need one that pumps the tyres up to 100psi easily.(i need 70psi)
The ones i have bought say they will do that but struggle after 65psi
Also a long enough electric lead from the cigar lighter to the rear tyres.
rich
mikejtaylor21
10
9
West Midlands
since 1999
For those of you with the screw on tyre inflators that let air out when screwing on an off the tyre valve you might want to explore these adaptors called Tyre Chucks from ebay or Amazon. I purchased 4 and am able to connect and blow up the MH tyres quickly and easily without having to resort to buying an new tyre inflator. Check out this link: Amazon product ASIN B07W4JM31S
Adam+Jude
19
11
Stockport
Swift Sundance 580
July 2018
rich
I've the same problem, athough my halfords pump works well enough, by the time i've unscrewed i loose pressure
Just been on the Ebay & found this...
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=143190851549
374
524
Chichester
Autosleeper Broadway
Since 2019
I use this with my Ring 900 and works perfectly, £10 from amazon
OXFORD Motorcycle Valve Conversion Access Tool OX753
2,746
9,544
Chester
Auto-trail
Well that`s our 13th year & still loving it.
As I said I'd done no research. If they're heavy (unless under water 😏) they won't be much use. They should be safe though - people wear them on their backs
You could buy a 7ltr cylinder cost about £190 then you are going to need a regulator and fittings probably going to cost another £60/£70 starting to get a little too expensive when you can buy a dual cylinder pump to run off the car battery for less than £70.
11,838
14,062
Eastbourne East Sussex
Hymer low profile
Since 1972
A cordless one does away with the long lead requirement.
I use this one
With a screw on to clip on adaptor that was a couple of quid from amazon.
I also use these, I have two, one in the mh and one at home. I also have in the mh a twin cylinder pump which runs off 12v with a long spiral hose which is quicker for a totally flat tyre.
Jim
Ringleader
Jul 19, 2007
36,315
130,209
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I would only place something that heavy on the end of a steel valve though (y) Deffo not a rubber one.
Edit :doh: read the description now :)
1,122
1,123
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
When I was a practising CDT teacher I spent a fair bit of time teaching the safety issues around oxy-acetylene cylinders, one highly inflammable with lighter than air gas - the acetylene and the other at 2200psi. the latter have been known to go through 7 brick walls when the top valve had been knocked off. The acetylene self combusts above 4psi in the atmosphere hence is held in an absorbent material inside the cylinder. When the kids asked me what to do if they did have an accident with the apparatus I would tell them to follow me out the door! ("Joke" - I would add).
173
474
Burstner td590 lyseo
campervan for 5 years, motorhome since May 19
14.5 psi = 1bar 14.7 psi = 1atmosphere.
14.51 to the fourth decimal place but who's counting :>)
Also, there is no standard atmosphere as it is changing all the time and dive cylinders fluctuate on filling due to heat.
Graydo
Wombles
10,802
11,106
SW England
Van Conversion
A few years now
After a Funster suggested this type of option we bought one like this https://www.topeak.com/global/en/products/floor-pumps/1079-joeblow--sport-iii (up to 160psi!) to try & it works very well. Not a lot of money for the convenience at home & can be carried on trips if wanted too.
63720
This week I was working with friends moving a heavy object with a 4 wheel trolly. As soon as the weight was applied we noticed all the tyres were f!at. My friend had a digital 12v inflator and pumped up one tyre, in the same time using a footpump I did the other 3. To be fair his battery might have been low but it could have been anywhere.
mikejtaylor21
10
9
West Midlands
since 1999
I've just weighed one of the Tyre Chucks and can inform everyone out there that they weigh 20g each. So would not cause any problems due to weight.
22
27
Newbie
After several pumps gave up on me above 60psi (only for the MOT to turn the warning light off) I bought a restored Kismet master (probably pre-war and used on Spitfire tyres). It works like a dream and the double cylinder mean it's no effort at all.
586
1,922
Soham, Cambs
Consort Oslo
Since 2016
Wombles
10,802
11,106
SW England
Van Conversion
A few years now
was going to look at a 12volt one, something like the Ring RAC 900, but may well look at one of these instead.
will also give a bit of much needed excercise🤣👍
It's not as much exercise as a foot pump so not too bad!
Chris CM
200
183
S.E.Cornwall
Devon Aztec XL PVC
Since 2015
I’ve got the same type as Jim, the trick with the screw on type tyre connector is to have the compressor running before you connect and don’t switch off until after you have disconnected from the tyre valve. This will minimise air loss.
82
176
Somerset
Nuevo called Mabel
newbie learning fast and sometimes the hard way
I use this one
I have one of these as well. Use it for cars, bikes, air suspension, MH tyres, blow up beds etc. Not the fastest but easy to use
EastAngler
97
73
Bury St Edmunds
Hymer B544 1993
Newbie
Why do you need 4? Surely a pack of 1 would do as you move it from tyre to tyre as you fill don't you?
mikejtaylor21
10
9
West Midlands
since 1999
I need 4 so I can convert some of my other car pumps from screw on to fast fit. I have several pumps. They can be ordered individually. I keep a pump in each of my 6 vehicles: 2 Cars, 2 Motorhomes one of which is a self build and 2 commercial vans.
These chucks screw onto the end of the original tyre inflater hose. They have a male threaded end thus converting the inflater to a fast clip on clip off. If you should ever need the screw on adapter for anything just unscrew the chuck and use the inflater as supplied originally.
65
156
Niesmann Bischoff Ar
Since 2016
I have purchased a dewalt dcc018n-xj. Can work with mains, 12v cigarette, and also the dewalt 18v battery. Great piece of kit!
JaveaSteve
26
20
Javea, Alicante, Spain
Hobby Premium T70GE
Thank you for this post, never heard of Tyre Chucks before but have some en route to me as I type. Fingers Crossed next time I inflate the air will not be so Blue...............
730
3,542
Bucks
Adria PVC
Rented a few times...now an owner.
So these inflators that work off crocodile clips... could anyone that has one advise please ....do you have to connect it direct to the engine battery?
I ask because for me (Ducato x290) that would mean lifting the cab carpet, undoing 6 plastic clips and lifting the floor panel?
Isn’t that a bit of a faff ? Can they be connected via the charging point under the bonnet instead ?
