TV problem (1 Viewer)
Arrpeekay
5
Benimar
25 years
I have a Benima 201 15 reg not been used during lockdown, now the tv does not work in the van but indoor all ok , 12v at amplifier but no pics . Coaxial tested any ideas please!!
Sep 3, 2012
7,531
26,007
Cheshire
C Class Elddis 175
8+ years
That happened to us, TV powered up but no picture, turns out there wasn't enough power getting to the TV through a faulty 12v plug in connection. Had to resolder a connection in 12v plug adaptor and all was OK.
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Where is the signal coming from? Does the TV power up?
A
Arrpeekay
5
Benimar
25 years
12v and 240v both change channels but no signal
Feb 17, 2017
459
1,920
Herefordshire
A Bit
Does your TV have a signal strength/Quality button so you can check if you are getting a signal from the aerial
Feb 5, 2020
2,374
88,761
Crosby
Smileo 202
Was a Newbie but getting the hang of it now.
I know that here in the North West all the free view have had to be returned have you been able to do that.
Also check Ariel socket where coax goes from Tele into wall as mine had pushed back into a void behind socket.
Have you got a long coax to try and get a signal from house to van and returned.
Feb 17, 2017
459
1,920
Herefordshire
A Bit
Also if you have HDMI in maybe try a Fire Stick (if you have one) or DVD player just to check if that bits working although come to think of it just press the menu button and that should show if the TV is on or not and if its getting enough power for screen to work OK.
If working OK in house I would suspect signal strength first
Mar 30, 2019
1,089
1,380
East Sussex
Trigano Tribute
Since 2017
Has it worked where you’ve parked it before,
We can’t get free view where we park ours due to the house being in the way of the transmitter.
