tv has no sound on 12 volts (1 Viewer)
kev filey
Hi, Thanks for letting me join here, I am Kev from sunny Filey and I look forward to posting regularly on this site. I do have a problem with my tv, it is fine on mains but as soon as I switch to 12 volts there is no sound, can anyone suggest possible reasons, thanks Kev.;););)
jumar
3,693
11,210
Spain
Hymer Tramp
Since 1994
Fit a voltage regulator when using 12v.....had the same problem a few years ago.
suavecarve
7,446
38,668
Surrey/Hants
Rollerteam 685
July 09
Probably best to post these type pf enquiries in a different section such as "chat" as you will get quicker and more responses. @jumar has probably hit the nail on the head but there are likely to be at least 5 more different answers on a more active thread. Good luck
Jul 29, 2013
9,048
18,084
Salisbury
Hymer B678DL A class
since 2011
:welco::hiya2:
We had same problem and discovered it was low voltage in leisure batteries just needed to charge them a little and all was ok.
Jul 29, 2013
9,048
18,084
Salisbury
since 2011
What type of TV switches between 12v & 240v?
Think it's when on hook up its charging batteries so always Google voltage on leisure batteries but as soon as you go wilding batteries not holding power or charger not working properly.
Oct 7, 2015
736
3,576
newark
Swift escape 624
Hi, We had the same problem on our old van, turned out the 12v socket was only giving about 8 volts rewired all ok. ps welcome.
tonka
10,795
21,440
Cannock, Staffs
A class Burstner 800
Since 2000
I agree. low voltage supply..
Check battery condition, socket and leads for tight and proper connections. (y)
and welcome to fun.
Sep 3, 2009
1,529
6,266
NW Surrey
LHD Hymer exsis-i
If it's an Avtex, we had the same, turned out to be the amplifier on the main board. Went back 3 times before it was fixed properly.
Malcolm
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
:hi2:w2f
To begin try starting a new thread in the Motorhome Chat forum part with your specific questions to get more replies and more will see your posts.
Keith
