Touchwood
- Aug 23, 2011
- 772
- 733
- Compass Avantgarde 140
- 5 years and learning
Our TV for the 'van is actually a 12v. model; it was supplied complete with a 240/12v transformer for running from mains.
I've almost always run it on 240v as we are usually on hook-up; I have run it on 12v. once using a piece of kit that enables voltage selection (12v, 15v. etc.) and I believe that this piece of kit supplies a "controlled" voltage which may, or may not, be necessary.
I could achieve a much neater installation, however, if I were to always run on 12v. even when on hookup - the transformer seems always to get in the way and it uses up an otherwise useful 240v socket.
Couple of worries though: -
Do I actually need the "controlled" voltage kit, or can I just plug in to the 'van 12v.? There's a handy 12v. socket combined with an aerial socket which is obviously intended for the purpose.
Am I in danger of overheating the inverter whilst on hookup? I'm not sure if the inverter feeds the 12v. socket directly , or via the leisure battery.
The TV takes about 4 amps - do I need to check the current carrying capacity of the 12v. cable/plug? What I'm proposing to use is a standard 12v. plug and what looks like bell wire.
Any advice, as always, greatly appreciated.
