Tube light (1 Viewer)
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Since 2011, previously a tugger
The 24" strip light above the sink and hob is on the way out I think. Mostly needs a tap now to get it on properly. It's a Sylvania Standard F18/129 -T8 warm white.
Derek from stores at Brownhills was most helpful on the phone but quickest he could get one for was after we leave for Spain week of 23rd Feb. Anyone any idea where I might get one quicker?
11,953
16,570
Any electrical wholesale outlet? They aren't specific to MHs / caravans.
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Why not replace with LED strip...
I have changed all my bulbs I just didn't fancy the re-wiring I would need to do on the strip lights just yet
I do not know of any wholesale outlets that supply 12volt lighting Tony?
musson
487
165
grantham
low profile
since Jan 2014
Hi try you tube it may show you how to fit the strip led,its not difficult they are marked at different lengths for cutting ,then you can solder your wires to the strip and take one through the switch thats fitted to the light.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
assuming you strip light is flourescent just rip all the interior out and use the two wires from the switch to join to the strips you do need to get them the right way round but no damage will occur if you get it wrong just reverse them
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Thanks both, I was given an old copy of MMM and it had a good article on doing the strip lights. I would do it, but with going away in a couple of weeks I didn't want to be doing it just now. The strip light will probably see me out for a couple of months, plus if it goes completely it won't matter too much in Spain :smiley:
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
Simple way..
Leave strip light in place but take out the tube.
Find the 12v feed BEFORE it goes into the light fitting...
Tap off here with some Crimp on joiners and use some LED strip lighting with sticky back.
This way your wall switch will work the same, you have your old fitting there "just in case" and it's a simple job.
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Simple way..
Cheers for the link. How many runs of the LED strip would I need to give the same 18watt that I get from the current tube.
tonka
10,829
21,524
Cannock, Staffs
Since 2000
There is a way to calculate but for the life of me I cant remember how to do it.
These come in 5mtr length and you can cut to the size you want and go the whole length under a cupboard if you want OR even run 2 strips in parallel if needed.
Many others on ebay, thats just to give an idea..
Mar 23, 2012
9,543
32,061
sleights
c class
The tube doesn't run at 12v that's why you can't just wire the leds to the fitting it runs at a high voltage supplied by the fitting and probably can be replaced by a standard tube. If you want the easiest fix (not led for the time being) take the old one to your local electrical wholesaler I bet they've got an equivalent in stock
trekkin
332
490
Staffordshire
Rv
5 years but still learning
These are generally the standard tubes, similar to the ones kitchen fitters use under the cupboards to illuminate work tops
Try Wilko, b&q homebase etc, right length right pin out should be ok
They work for us
Mar 23, 2012
9,543
32,061
sleights
c class
This explains what the markings mean and looks like the one you need best to take the old one in though bet it's a quarter of the cost compared to Brownhills!!!
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
They work for us
So your saying it's a fairly standard tube and the bit of circuitry in the housing steps up the voltage from 12v to enable a 240 volt light to work? I can't quite get my head around that o_O I have to say, this looks like it in Screwfix at £2.99?
http://www.screwfix.com/p/sylvania-...8w/75145#product_additional_details_container
Nov 4, 2011
5,936
38,890
Uk
Yes they are just normal household tubes, don't need to go to motorhome dealer.
Dave and Ginny
Dave and Ginny
1,569
1,582
Nottingham
Hymer Starline 680
Well I never, £2.99 from Screwfix, works a treat. Thanks everyone!(y)
The guy at Brownhills was very helpful, but they were going to order one in, from Hymer @ £19 !:eek:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I got a replacement tube from a local lighting shop. The base / pin standard is G13 according to Osram.
24" / 600 mm seems very long - I know the over-sink tube in my Hymer is shorter. If it is the 600 mm version, they are available in Homebase:
http://www.homebase.co.uk/en/homebaseuk/tcp-tube-18w-600mm---1-pack-899678
Also several 18W versions to choose from in B&Q. If you need a shorter version then the DIY sheds appear not to stock them and you may need to find a specialist shop as I did.
By the way - I decided against stripping out the inverter in the light unit and fitting an LED strip; the fluorescent tubes use less than a halogen light anyway.
