Truma ultraheat
Stratford-upon-Avon, UK
BUCCANEER CARAVEL
SINCE 1975
Up at Fort William,instead of France temperature a bit different!We Havnt used the Truma heater on gas for years!I think the igniter has gone ! hasn’t bothered us as havnt needed heating very often and when we have we have put it on electric!But now we could do with some heating it is playing up on electric.appears to work sometimes !not working tonight!Switched on.green light on.selected 500,1000,or 2000 20* on thermostat.nothing!any ideas?
Your frozen body will be picked up tomorrow morning. 👻
It’s not that 🥶 I still think it’s warm and I’m still in shorts 🩳. I can’t help with your heater but I would have checked it was working ok before leaving and coming to the frozen north ☠️ Have a wee dram or 3 that will warm your vitals 😷
Tried it before left home for the frozen north and it worked but over last few days it’s worked some days and not others!Old need it on to take the chill off😊😊
If you've a Truma S3002 convection heater and the igniter isn't working, first stop is the igniter battery (1x AA IIRC), bottom right front of the heater.
On mains, if you've a green light on the Ultraheat display when you've selected 500, 100 or 2000, you should be getting power. Have you turned the numbered thermostat to 9? If it's at the bottom end of the range it may be warm enough not to trigger the thermostat.
That's the limit of my suggestions, sorry..... 🙂
Put a new battery in igniter but still not working!just tried turning thermostat down.watch this space!😊
We were there two weeks ago and it was baking... it’s amazing how quickly things change isn’t it
Nip into Argos in the morning and buy a fan heater.
Fit a 5KW Chinese Diesel Heater
{ Copy of an Eberspacher type dearer version}
You won't be cold anymore.
Fan heater from Argos!best solution for the next weeks as forecast isn’t good,Then will try and sort truma out!
