- Nov 25, 2020
- 85
- 36
- AT Dakota SE - Merc
- Pretty much got the hang of it now!
Hi All (Again)
I have a Truma Ultraheat in my Autotrail Dakota SE 2003 that initially worked on 240v when I tried it a while back. On 240v hook-up, the green LED illuminated and I was able to select either 500, 1000 or 200w. The knob allowed me a range of from 1-9 stat settings. The fan on the heater unit worked and hot air blew out from the vents albeit rather weakly (is this normal?). After 20 mins it stopped. The green LED on the control panel was not illuminated. When I turned it off the LED illuminated faintly for a millisecond then went out. This it did for a few weeks each time I tried it but now it won't illuminate at all. The fan works I presume on 12v and not 240v as it would have to work on gas if no 240v available by hookup? All the MCBs are fine. Changed fuse on Ultraheat isolating switch all good too. I have just put in a new EC328 and matching control panel all working fine. As I have yet to have its first habitation check since we bought it in November 2020, I don't want to try the heater on gas until a professional has checked all the pipes, joints etc. From any wise heads out there, do you think it would most likely be the control unit or perhaps a pcb/other component gone west in the fire itself?
Paul
Paul
