Bart
So I've finally got around to relocating the thermostat Sensor on our 6002 Truma heater in our Bessacarr E560 due the stupid location that it is mounted in ( above the habitation door at roof height ) which means that the heating does not cut in and out very well.
So atm i have just extended the wires on the sensor and am trying it out in different places when i noticed that it seemed to work well , as in keeping the MH a constant temp rather than before it being roasting and then having to turn down the thermostat , to discover 20 mins later the MH freezing with the heating not restarting again until you turned up the thermostat again by quite a bit.
Now i have tried the sensor about 6" from the ground on the side of the lounge seats and this seemed to work well , HOWEVER i did notice that the heater ran nearly constantly with the fan blowing at the SLOWEST speed it could , this seemed far better than previously where the Heater would NOT run for a long time but when it did run the fan ran at its FASTEST speed for most of the time until MH is like a sauna.
So yip i know i rambled on a bit but here is my QUESTION , will there be a difference in gas usage between
1. Heater running some of the time , but blowing the air out of it at its Fastest speed
2. Heater running most of the time , but blowing the air out of it at its Slowest speed
to me option 2 is far better , but i'm worried that the gas usage will rocket , as we only wild camp and the gas heater is used often.
Does the heater unit inside the heater burn gas at different speeds , the same way the 12v Fan in the heater blows at different speeds ??
