Truma rapid W/heater 10ltr
Thame UK
boxer compass 140
A newbie solo
Hi I’ve a 56 plate elddis on a boxer chassis the water heater works on mains ok, but not on gas. There’s no green light at all when I switch it to gas I’ve checked all fuses including the one on the pcb all ok. Could it be the pcb? All suggestions great fully appreciated
More info needed to be able to consider a useful response. Such as the make and model of the heater. How have you checked that there is a gas supply - do the gas hob rings work ok? Are the gas valves open? Any fault codes showing? Warning lights etc?
i sent my pcb back to truma to be checked it came back as ok but never did get it working and bought a new heater
I was sure I answered this one . Confused now
Great to hear it's sorted. Did you fix the problem, was it a simple fix, or maybe a new circuit board, or was a new heater necessary? And did you find out which model it was?
High Five Boom GIF by TipsyElves.com
Looking at the thread time line , you might have to wait till December for any further update ;).
Mike.
After a lot of chasing with the multi metre found the fuse was good but no power after removed fuse board complete and found a bad soldered joint completely hidden from view , made by previous owner . Very relieved to say the least cheers all for your help ,jack@32100
