TRUMA long data cable replacement (1 Viewer)
smiffy64
77
59
Fife, Scotland
Coach built
Newbie
I have recently diagnosed that my long data cable for my Truma combi6e is faulty.
I am not sure why a data cable suddenly stops working. It is not a moving part that wears out.
Anyway, that is what it is as my heater works when I put the short cable in.
I have a Dethleffs T7150 DBT, where the rotary controls are above the entrance door and somehow snake through the van to the Combi which sits under the rear fixed bed at the opposite side of the van.
I have a new 6M cable.
I have already been warned by someone, who did not give me much confidence that he knew what he was talking about, that I would be as well to reposition the controls closer to the appliance.
I am not sure about that.
So do you guys have any advice in how the cable is usually routed?
I see that it seems to go from the controls, through a small pipe box in the unit above the fridge and then seems to go down behind the fridge. So I hope I do not need to remove the fridge.
Is the cable routed outside and under the van at any point?
Thanks in advance,
Raymond.
smiffy64
smiffy64
77
59
Fife, Scotland
Coach built
Newbie
OK...getting somewhere.
The cable is routed through to the toilet, which in turn is routed through a corner unit in the bedroom. So not going outside and not going behind the fridge. Thank God(y)
Should be easier than I thought.
Lenny HB
50,179
138,273
On the coast in West Sussex
Hymer B678 DL
Before you replace the cable how old is the CP plus?
Early ones used to fall over on long cables, I had one (2014) that often fell over when the timer was set. Softwarere update cured it.
smiffy64
smiffy64
77
59
Fife, Scotland
Coach built
Newbie
The boiler is a 2012. Older design I think. The lights are totally dead. I plugged in the new cable and it is fine.
I have managed to pull it through the trickiest section at the toilet with a thread attached to pull the new one through.
I have had to remove some shelves to then in turn remove plastic cable conduits. So far so good. Going too good actually. Something is bound to go wrong.:cautious:
