Truma gas regulator problem (1 Viewer)
OllieUK
259
300
Ramsgate
Bessacarr E520
Pre-check today regarding gas and electric heating, I now find that I cannot get any gas (Heating, Stove, or Fridge ) to work. Checked gas propane bottles both full, pressed green reset button on regulator, checked green and blue taps inside the van were in the "On" position.
NO gas getting through. I think I must have a defective regulator. A right bummer as I was going to have a week away from tomorrow.
Can these regulators be serviced? or is it a replacement? that is needed.
As an after thought would this be a good time to upgrade to a Gaslow system ?
by the time I pay for a replacement regulator and fitting, how much would the difference in cost be?
Can anyone give me a quote on a Gaslow system fitted please.
lunarman
2,147
2,438
South Glos
since 1994
You would still have to replace the regulator. The gaslow only replaces the bottles using the existing regulator.
Wickolad
490
542
Wickersley
Tyou could get a replacement truma regulator ( costly ) or why not just get a regular propane or butsne regulator and an adaptor to fit the hose to the system. I think the regulAr propane regulator are not as sensitive to the oil contamination from the gas bottles. There must be an adaptor to allow a push fit hose connection which should allow you to continue with your holiday plans :)
Scattycat
920
1,262
Mayenne, France
Rapido
What size is the feed from your regulator to the appliences?
I have an 8 mm one that I bought but needed a 10 mm so I could let you have the 8 mm at a good price if you're interested
bobandjanie
8,143
15,699
Javea, Spain
Pilote V600g
If you have the secumotion regulator with the button you should also have buttons to push down on your hoses near the valve on the gas bottles. :xgrin: Bob.
17,509
42,755
the more reliable gasit or cleese regulators are only about £20
OllieUK
OllieUK
259
300
Ramsgate
Bessacarr E520
I need a 10 mm,
I didn't check the feed hose for any buttons, will look in the morning .. Thanks.
Dazzlin
1,749
6,212
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
I will have it now ben does not want it. I used my spare a couple of weeks ago.
We will be passing on the way back in may! If its gone by then no probs.
Scattycat
920
1,262
Mayenne, France
Rapido
Timing is fortunate, we expect to be back home around the end of April.
