Truma fault code e202h
Motty
My heater runs for a few mins the cuts out !
Gas bottles are full
If i have the cooker burner on ,when i put the heater on the gas flame drops !!
it works great on EHU
Help !!
Jul 29, 2013
6,907
9,189
Salisbury
Hymer B678DL A class
since 2011
What gas are you using propane or butane? As I recently discovered after refilling our Gasit system in Tarifa that the mix of gas was higher in butane and we had problems with boiler until we had used it up.
EX51SSS
6,075
29,060
North Manchester
Hymer Exsis A Class
since 2007
two
Aug 4, 2011
4,400
3,437
West Midlands
A-Class Fiat
That might be what you think, but where are you getting it from?
On the continent, they use a mix of Propane & Butane. When it's really cold, the Butane does not evaporate and, bit by bit, you can end up with a cylinder full of Butane.
