My van is an Adria 600SP and has an in tank water pump. The water pump is working, the one way valve above it is working correctly but no water comes out of the taps. If I operate the Truma frost protection valve by turning the switch on the top the water in the system is dropped. If I then turn the switch on the top a few times and then close the valve water is pumped, the system fills and the taps work. After a while if I try the taps again the pump runs but no water gets to the taps. Does all the pumped water go through the Truma dump valve before getting to the taps? If so the problem must be the dump valve and I will need to dismantle it or am I missing something? Thanks.
